Hello all; I have most of the stuff for conversion now. Got the Kl-5056D and the Kl -8070D drivers. Do you wire them like the 5056s ? Don't see a wiring diagram for the Digital drivers. Is it the same as the standard drivers? I got the 4 axis control box. The Kl-4813 Power Supply is a tight fit in the box, but I can get it in there. I might have to trim the base a bit. Should I use the same shielded wire for wiring the inside of the Box ? I downloaded info on all the stuff I got. Do I need the ProTuner software for tuning motors? I know Mach 3 does that too.
Lots of ? Sorry..... Mitch (USN)
