Guys,
Can I connect EMC2 on LinuxCNC with LPT directly into my stepper motor driver ?
Is it possible for me using USB to LPT converter since I can't find a parallel port on my computer ...
Guys,
I have used it. You will need to get a parallel port card for your computer.
Read everything you can on the LinuxCNC.org site.
Generally, 0,0,0 is set using limit switches and a homing routine. You can daisy chain the limit switches so they share one input (pin) on the parallel port.
Stan
bianchi,
You can pick up an old desktop for next to nothing that will run linuxcnc.
Stan
