586,477 active members*
3,536 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > Is actual cutting speed slower or curved than straight lines?
    Apr 2012
    I have an old Thermwood 45. All the curves are thousands of straight lines. But whats the most modern curve interpolater out there? I need to know if modern machines and CAD/CAM can cut curves as fast as straight lines.
    thanks
    Zach
    May 2004
    4519
    The answer really depends on the machine and the control. Some machines have advanced so that axis moves are synchronized to achieve near perfect feeds on moves not parallel to an axis. Others just achieve an approximation of the programmed feed rate. And some machines can be switched between the two conditions at will.
  1. Straight Lines on Curved Surface.
    By Navatek in forum CNC Tooling
    Last Post: 08-15-2011, 11:45 PM
  2. problem with lines not cutting straight after engraving
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2009, 04:27 AM
  3. Where are the darn curved lines?
    By teamtexas in forum Mach Software (ArtSoft software)
    Last Post: 06-24-2008, 02:46 AM
  4. creating a straight c-bore on a curved surface
    By bennett71 in forum Solidworks
    Last Post: 02-14-2007, 07:58 AM
  5. Slower Jog Speed
    By rweatherly in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-18-2006, 07:33 PM
