I have an old Denford CNC Starmill.
I don't have a lot of machining experience as I am only a hobby machinist so I was wondering if there was anyone more experienced on here that might know the cause of the problem I'm experiencing.
I have just machined a flat face on the top of a block of mild steel. If you look at the attached image you will see that the resulting finish is terrible. I used a 10mm cutter and the depth of cut was only about 0.3mm.
You can see that I have ended up with quite visible "rings" from the cutter. They are clearly visible but only just detectable when running a finger across them so in essence are not as bad as they look.
Has anyone seen this before and have an idea what causes it?
Thinking logically I can only imagine that the cause must be some sort of play in the Z axis?
Anyone got any thoughts?
Many thanks in advance.
