586,384 active members*
3,755 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Connecting Delta spindle drive with Fanuc 0i-MD control
    Oct 2010
    131
    I want to connect a delta inverter drive with Fanuc 0i-MD control....
    I have already connected the drive and it is working for Forward, Reverse and Stop commands(MO3, M04 and M05) which is given to the drive as a output address Y0.0, Y0.1, Y0.2. Now i am not able to control the speed through the NC control. How to interface the drive with the control for speed control.
    Please help....
    Oct 2010
    131
    Nobody here knows the solution for this....????
    Jul 2008
    156
    Re: Connecting Delta spindle drive with Fanuc 0i-MD control
    I know this is an old thread but the more documentation the better. The usual way Fanuc sends a speed command is either by a 0-10VDC signal where 0V=0RPM and 10V=Max RPM, or by a 12 bit address where 000000000000=0 RPM and 111111111111=max RPM. Most VFD's that I have worked with have had the 0-10VDC input and in fact the Delta VFD-E that I just put in has it. Hopefully that is what the Fanuc 0i-MD does. if not (as in the case of my Fanuc 6M control) you will need to do some sort of translation. We used an Arduino to read the 12 bit speed command from Fanuc and then output a 0-10VDC signal using an external DAC.
  1. Replies: 2
    Last Post: 04-10-2013, 01:07 PM
  2. can use vector drive for control router spindle?
    By bel630 in forum DIY CNC Router Table Machines
    Last Post: 12-08-2012, 11:35 PM
  3. Connecting a breakout board to spindle speed control
    By waisberg in forum Commercial CNC Wood Routers
    Last Post: 10-25-2012, 08:04 AM
  4. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  5. Delta 3 phase and Fanuc control
    By scadvice in forum Fanuc
    Last Post: 01-13-2009, 09:15 PM
