586,317 active members*
3,422 visitors online*
Results 1 to 9 of 9
    Aug 2007
    5
    S03 alarm on mitsubishi
    hello,
    can anyone help me with th emeaning for this alarm on my mitsubishi control;
    S03 SERVO ALARM 005F Z AXIS
    i cant find any reference to this message in my manual...
    cheers
    mike
    Jun 2008
    150
    Hello Mike,
    I don't have a listing of a 5F alarm either. If you look in your electrical cabinet the Z axis amp should be displaying an alarm code as well. What is the drive saying? What model is the drive?
    Lee
    PS- A 700/70 Series Handbook says that a S03 005F alarm is the external contactor points are welded together. This could be an external or could be the internal contactor. Also I have seen the scr bad and the red DC Buss indicator lite on the base of the drive is not on. Or it could be on as soon as power is applied to the machine but the servo ready signal is not enabled yet. Something to that effect. Check out the power circuit on the Z axis drive to be sure nothing is amuck.
    Aug 2007
    5
    hi, check out the pic, this is the Z drive. It shows an SF message. Something to do with signal from the motor encoder maybe?
    Jun 2008
    150
    Hi Mike,
    I was adding info to my original post when you posted the picture. I found a 5F alarm in the MDS manual. It mentions the external contactor being welded. I guess anything along those lines as the contact points being stuck or a dead short in the amp base unit. Good luck to you. Prolly gonna have to shotgun the drive. Hope not.
    Lee
    Aug 2007
    5
    ok, thanks, i will check it out and post the result.
    cheers
    Jun 2008
    150
    Here is the page out of the manualPages from MDS-B-SVJ2.pdf
    Aug 2007
    5
    great, thanks for that.
    cheers
    Aug 2007
    5
    turns out this alarm is pointing to a fault in the Drive. Have replaced the drive and all good again.
    Re: S03 alarm on mitsubishi
    I have a very similar issue with my 1995 Supermax Max-1 Rebel I just picked up, it’s got a Mitsubishi meldas m3 controller and I finally got the power supply from the 3ph rotary and flipped the switch, heard a pop fizz! Noise and saw smoke, but couldn’t pinpoint the location, but the machine powered up and seems to be operational, so I let it go, turn on the NC, and it works, the screen showing S03 SERVO ALARM :NR 0057 I check the box and on the RF203 I get F157, F257, F357, and can now see a transistor? I believe, on board RF23. Video on my Imgur https://imgur.com/gallery/T4a7jKV
  1. MITSUBISHI MELDAS 500 alarm
    By el gordo in forum Mitsubishi controls
    Last Post: 10-02-2012, 08:17 PM
  2. Alarm 16/20 with Mitsubishi MR-J2-100a
    By AFAIK in forum Servo Motors / Drives
    Last Post: 07-30-2012, 03:36 PM
  3. Mitsubishi servo amp MDS-A-SVJ-03 alarm
    By BRmaintenance in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2012, 01:26 PM
  4. '2D' alarm on Mitsubishi 50M control - anyone know?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 02-18-2008, 05:48 PM
  5. Mitsubishi IPM overheat alarm
    By rjboz in forum Daewoo/Doosan
    Last Post: 12-22-2006, 09:46 AM
