587,067 active members*
3,651 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Redsail Laser > Big problem with laser engraver m500 /REDSAIL/
Results 1 to 7 of 7
    Dec 2011
    Exclamation Big problem with laser engraver m500 /REDSAIL/
    Hello
    my problem is this ... doing Stamp basis .. but not equal to equal, even at times reached the level of letters and printed accordingly.
    Please someone advise me what the problem is!
    Thanks in advance!
    May 2011
    Are the deeper cut sections nearer the end of the laser where the beam exits?
    If so I would suggest mirror alignment......the beam is weaker the further it is from the laser tube.
    John
    Dec 2011
    Hello
    nothing changes. We changed blocks for high voltage interfaces changed the board changed the wheels for movement along the axis "Y". The result is the same. Tomorrow I will change and the lamp. If anyone has other ideas and please help.
    thank you
    Dec 2011
    I changed the laser tube and all is well.
    Apr 2006
    108
    Please pay attention to the laser power supply. I have noticed problems like this when there was a power supply with low voltage output, running hot, .. just not a match to the laser tube.
    You should also look at these suggestions:
    *Use a power line conditioner .. Similar to TrippLite model LC1200
    *Ensure a proper ground from the laser machine frame to a "real" building frame
    *Do not run any "odd" equipment with motors while operating the laser (blender, saw, router)
    Ray Scott
    Owner / Engineer
    Rabbit Laser USA
    513-217-5707
    Dec 2011
    laser tube
    I changed the laser tube and everything is fine.
    Jan 2012
    hi ,can you gelp me? I am lookig forward to make a stamp in this machine. I have o idea how to make it. Please let me know. I already alligned the mirrors but I havet got the nice stamp.
    Joathan Rivera
  1. Redsail M500
    By SHADOW042 in forum Redsail Laser
    Last Post: 04-18-2020, 06:57 PM
  2. Redsail M500 spare laser tube
    By SirQuickly in forum Redsail Laser
    Last Post: 03-01-2019, 04:18 AM
  3. IEHK IE-500 vs. RedSail M500
    By AudubonCreek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-17-2009, 05:13 PM
  4. Redsail low cost lasers (M500) - Any suggestions?
    By eyoung3 in forum Redsail Laser
    Last Post: 02-24-2009, 12:46 AM
  5. M500 Redsail Ghost Image
    By reneisla in forum Engraving Machines
    Last Post: 12-15-2008, 04:59 AM
