586,596 active members*
2,990 visitors online*
    Jun 2009
    108
    Fagor 8025GP Problem
    Hi, I have a serious problem in control Fagor model 8025 GP, several alarms appears after the screen monitor was repaired, Error 64 Emergency, Error 111 LAN error, Error 099 Parity errorMs, Error 075, 076, 077, 078 Axis Feedback (all axis).
    Someone could help me please?
    Dec 2011
    73
    Sounds like your parameters may not be good. Do you have a known good back up? If so load those into the control and then cycle the power on and off.
    In the case of the feedback alarms, are your cables on the feedback ports? are you cables known to be good?
    If the parameter reload doesnt solve the issues, i would say call fagor. there could be a bigger issue at hand.
    Apr 2023
    Re: Fagor 8025GP Problem
    Hi, Quite an old thread but I have exactly this issue too. I am calling Fagor tomorrow for assistance - did you get this issue sorted?
  1. problem with cnc fagor 8025
    By mamadoo95 in forum Fagor Automation
    Last Post: 12-30-2011, 03:53 AM
  2. 8025gp error code 68
    By dyer215 in forum Fagor Automation
    Last Post: 06-09-2011, 07:15 AM
  3. 8025gp x axis following error
    Last Post: 02-22-2011, 12:50 PM
  4. 8025GP program problem
    By Al_The_Man in forum Fagor Automation
    Last Post: 02-06-2011, 12:41 AM
