586,290 active members*
3,877 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD CAM V24 Standard / BobART
    Mar 2012
    1570
    File Import:
    CAD – Legacy BobCAD-CAM
    DXF – AutoCAD
    DWG – AutoCAD
    STEP,STP – Step
    IGES,IGS – Iges
    SAT – ACIS
    3DM – Rhino
    X_T – Parasolids
    X_B – Parasolids
    SLDPRT – SolidWorks
    BBCD – BobCAD-CAM
    STL – Stereo Lithography
    File Export:
    IGES, IGS – Iges
    DXF – AutoCAD
    DWG – AutoCAD
    SAT – ACIS
    3DM – Rhino
    STP,STEP – Step
    BBCD – BobCAD
    Surface Creation & Tools:
    Planar
    Skin
    Revolve
    Offset
    3 Edge
    4 Edge
    Cross Section
    Extrude Curve
    Extrude Surface
    Multi-Sided Patch
    Fillet
    Extend Surface
    Intersection Curves
    Un-Trim Surface
    Break Surface
    Sweep
    Solid Creation & Editing:
    Sphere
    Cube
    Cone
    Cylinder
    Torus
    Fillet
    Add, Subtract and Intersect Booleans
    CAM Features:
    Wizard Driven CAM
    Tool Database
    Speed & Feed Calculator
    Save & Load Tool Path Setting
    Associative CAM
    Tool Path Simulation
    CAM Tool Paths:
    2.5 Axis Drilling
    2.5 Axis Profiling
    2.5 Axis Pocketing
    2.5 Axis Facing
    2.5 Axis Chamfer
    2.5 Axis Threading
    2.5 & 3 Axis Engraving
    2D & 3 Axis Plunge Roughing
    3D Slice Planer
    3D Slice Spiral
    3D Engraving
    3D Slice Radial
    3D Z-Level Roughing
    3D Z-Level Finishing
    4 Axis Indexing
    4 Axis Wrapping
    BobART:
    Import – .BMP, JPEG, PNG, EPS, AI, PDF
    Photo Embossing,Turn Pictures directly into 3D Relief/Embossed models
    Raster to Vector Conversion
    Embossing & Debossing
    Emboss from dxf files or solid shapes
    Texturing
    Mirroring
    Lettering
    V Carving
    2-Rail Sweep
    Sculpting
    Smoothing
    Material/Texture Selection
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Sep 2010
    So, I have to have BobART in order to import a photo? Or, can it be done in V25 standard?
  1. Vetric or BobCAD-CAM v24 mill/BobART Pro?
    By reflectivist in forum Uncategorised CAM Discussion
    Last Post: 04-18-2012, 05:45 AM
  2. Bobcad bobart evaluation help
    By becikeja in forum BobCad-Cam
    Last Post: 06-12-2007, 11:33 PM
  3. BobCAD/BobART question
    By shootingarts in forum BobCad-Cam
    Last Post: 10-14-2005, 02:40 PM
  4. NEW BobART PRO-X from BobCAD-CAM
    By CNCdude in forum News Announcements
    Last Post: 06-14-2005, 02:27 PM
