586,471 active members*
3,659 visitors online*
    Apr 2012
    Fanuc 10m parameter backup
    The controller is working with Fanuc 10m. I need to find a way to backup the parameters. Does anyone have a manual or a "how to backup step by step" for the Fanuc 10m?
    Mar 2008
    150
    Punch out Parameters:
    Select SERVICE screen.
    Press PUNCH.
    Press ALL.
    Write down Option Parameters (or check if they were sent out with the parameters):
    NC PRM #9000Number of axes
    #9100-9116 / 9100-9132 Option parameters (depending on model).
    Write down PMC Parameters (NC/PC):
    Timers
    Counters
    Keep Relays
    Data Tables
    Positioning Module (if present)
    Punch out Programs:
    Select EDIT mode.
    Verify Program Protect Key is OFF.
    Select PROGRAM (MEMORY) screen.
    Press PUNCH.
    Press ALL.
    Punch out Tool Offsets:
    Select EDIT mode.
    Select OFFSET screen.
    Press PUNCH.
    Press TOOL.
    Again, make SURE you have Option and PMC parameters!
    Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
    Yes, they are old..... but i still like them!
    Mar 2008
    150
    You will also need your 8000 and 9000 programs. These have a parameter that locks them so make sure that they get backed up. They will not “punch” out of the control if they are locked.
    To be able to write, punch or edit 8000 programs, parameter 0011.0 (bit 0) to a "0", for 9000 programs, 2201.0 to a "0".
  1. Fanuc 15T Backup Information
    By Swarf Bin in forum Fanuc
    Last Post: 11-30-2012, 05:29 AM
  2. Parameter backup on Yasnac 2000 G2 controller
    By yappiday in forum Controller & Computer Solutions
    Last Post: 09-07-2011, 03:23 PM
  3. Parameter Backup on 0i Mate-MB
    By rbcmetalwork in forum Fanuc
    Last Post: 01-30-2010, 06:42 AM
  4. Parameter Backup
    By cncboy1 in forum Okuma
    Last Post: 11-18-2009, 07:52 PM
  5. Mazak Fusion Parameter Backup
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2008, 05:42 PM
