I have finished building the driver boards and the x-axis and hooked it all up to see it go and it was slooooooooow. This is waht I have
L297/298 driver board (from the book CNC robotics)
276 oz.in 4 wire motor 2.8A 1.8 deg/step
Computer Power supply so 12 volts
the x-axis is a larger gas pipe and skate bearing set up
5/16-18 threaded rod for the screw
tested using KCam
When it worked it was very slow. I upped the jog IPM and it got slightly fasted but I couldn't get that number above 15 or so without it just making a loud buzzin sound and not moving at all. I understand that the cutting speed needs to be slow but shouldn't this thing jog reasonably fast.
Speed aside the set up is spotty at best. Sometimes you turn it on and nothing happens sometimes it works fine. I am not sure why because this same driver turned my earlier motor(much smaller) with no problems at all.
Any help would be apreciated,
John W
http://home.comcast.net/~pwprojects
