586,508 active members*
3,309 visitors online*
Page 1 of 3 123
Results 1 to 20 of 51
    Mar 2006
    101
    welded metal frame desktop cnc
    here is fairly small machine intended to be mounted on table
    outer dimensions will be about 1x1x1m
    and working area is somewhere around 700x700x200mm or slightly bigger than 2x2'
    here is visualization from solidworks, missing spindle with mount and table (which hopefully will be a vacuum table sometime in future)
    got some metal cut
    bevel it a bit
    and start cleaning
    nice and shiny
    parts cut with waterjet
    ...also needs cleaning
    a little bit of assembly
    and alot of drilling
    this is how lower part should look like, just needs some holes and tapering
    next thing on menu will be welding ... so stay tuned
    there is a bit more pictures on my website if you wish to take a look ...
    Feb 2012
    I thought mine would be heavy when built but yous must weigh at least 50/60 kilo's?
    Apr 2009
    5516
    Nice work!
    Apr 2007
    1955
    Thanks for posting your build. I looked at your blog and saw the anti - corrosion liquid bath with antikor. There is a company in Belgrade in the anti-corrosion business, but not a lot of information on the liquid itself. Do you happen to know what it is ?
    It looks like it both cleans and imparts a rust resisant surface to the steel ?
    When I was younger, I used some stuff called "naval jelly" which contains H3PO4 / phosphoric acid. I wonder if this is similar ?
    What size tubing are you using ?
    Nice work,
    Harry
    Jun 2011
    are you planning on tig welding it?
    Feb 2012
    The better brand in the UK is....
    Liquid Engineering UK - Corro Dip
    Feb 2012
    Mar 2006
    101
    Only that bottom table weight around 30kg..
    There is phosporic acid in antikor, but i don't know what else
    As i have co2 mig welder, that's what i'll weld if with
    Need to figure out a strategy how to avoid warpage
    Aug 2008
    409
    Are those rails supported or unsupported? what do you plan on machining with this machine?
    Feb 2012
    Corner tack then weld the top pieces,by the time you have finished the top welds they will have cooled, turn it over and do the bottom welds, then side welds.
    Keeping the welds cool in between welds helps and you have done the right thing by chamfering the edges,only a qualified welder can reduce warpage in their experience,there will be some warpage but only slight if methodically welded.
    Jan 2008
    853
    Quote Originally Posted by HorridHenry View Post
    HH : How does the chamfer reduce warping?
    Feb 2012
    Did I say it will help reduce warpage? the job he's tackling needs to be clamped down solid if he's not going to lift one of the pieces slightly at one end to account for the metal cooling and contracting back into a straight plane.
    The thing about welding is keeping the weld cool where/whenever possible and thats why its best to increment weld.
    Jan 2008
    853
    OK, let me rephrase. What are the benefits of chamfering ?
    Mar 2006
    101
    rails will be supported, but might deviate from original idea (which was to use some triangular spacers for achieve same distance over whole length of rail)
    which might prove bad way to go if tubes are not flat enough
    original design
    and use bolts with few nuts to get correct height of both rails at what ever point needed ... will see how this goes ...
    something like this
    main purpose of machine is for plastics and possibly aluminum, but testing will prove actual capabilities ...
    chamfer should enable weld to penetrate deeper if you have lower powered welder (like myself), and also help not to get too much of "bump" above line of tube ... so less grinding required if you wish to keep flat surface ...
    yes, idea is to get everything as square and level as possible than carefully tack weld each tube at 3 or more spots, and if nothing is out of shape, start welding small beads as far as possible from each other, to keep it cool as possible
    btw all tubes are 50x50x3 mm and metal sheets are 4mm thick, except few bigger ones that goes on Z axis which are 6mm
    Jan 2008
    853
    Quote Originally Posted by turpija View Post
    Thanks for the welding tip turpija!
    Jan 2009
    123
    Better off going with commercial machined rails and using shimes underneath to control height. I think you end up wasting hours and hours trying to adjust your rails and still have issues causing flexing and inaccuracies.
    With your new design you will need two nuts. If you apply a nut at the top of the square tube, there will be slack between bolt head and the nut permitting movement (up). In your original design the bolt head was applying force to the rail. You also introduce horizontal flex movement without the triangle wedges that would divert horizontal forces into tube frame.
    Apr 2009
    5516
    Another idea would be to use metal saddle washers, then you could just shim the washers.
    However, I do have to agree that it might be easier to buy the supported rail, and more accurate as well...
    Mar 2006
    101
    I am planing to use one nut underneath the square tube (actual bolt will be longer and head will serve only to tighten screw into rail), but i have same concern avout horizontal flex... Do you have any better idea hoe to keep adjustable height and add additional support ? I'm pretty much out of inspiration ... And yes, commercial supported rails are a better solution, and are also out of my budget
    Mar 2006
    101
    let's the welding begins !
    or tacking actually ...
    first, main frame
    then, everything between
    and done
    same technique used on those
    pile of metal starting to look like something
    next on menu is a deep breath and fully welding all the pieces ...
    Sep 2005
    540
    It looks like you are well on your way to having a nice machine....
    Robert
Page 1 of 3 123
  1. CNC metal C frame build
    By Tristar500 in forum Uncategorised MetalWorking Machines
    Last Post: 11-24-2013, 12:51 AM
  2. How much movement in a welded frame?
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 05-05-2011, 11:30 AM
  3. Gantry VS. C frame for metal mill
    Last Post: 11-21-2006, 12:48 PM
  4. Heat treating A36 MIG welded frame
    By ad_bfl in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2006, 08:07 PM
  5. cnc metal frame
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 02-06-2004, 09:59 AM
