586,619 active members*
2,424 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > MACH3 4 AXIS CNC Hand Wheel For ModsMach3 Engraving Machine MODBUS MPG Pendan
    Sep 2010
    54
    Question MACH3 4 AXIS CNC Hand Wheel For ModsMach3 Engraving Machine MODBUS MPG Pendan
    On eBay I bought MACH3 4 AXIS CNC Wheel Hand Engraving Machine For ModsMach3 MODBUS Pendan MPG. Besides, I got some basic instructions how to configure Mach3 to operate hand controls. The problems begin when I try to move the axis of the keyboard. The axis moves about 3-4 mm and then stops, and if I want to move the axis to increase the length I need to press on the keyboard. If you try to press home, but each axis moves to 3-4 mm mach 3, Digital readouts set to zero. I have tried all possible settings on manual control, but it is no different. I tried to disable command from the COM1 port. If you turn off the port and pin settings / Mod Bus input and output support in the general config Run macropump keyboard operates correctly.
    Sep 2010
    54
    I changed the Mach3 Version R3.043.022 to Version R3.043.020 and now MACH3 4 AXIS CNC Wheel Hand Engraving Machine For ModsMach3 MODBUS Pendan MPG works ok.
    Jan 2007
    18
    Me to
    Quote Originally Posted by kunte View Post
    I am having the same issue, where did you get the Version R3.043.020?
    Roy
    Roy - Pahrump, NV USA
    I don't want to hijack this thread, but I am wondering if anyone has tried this model:
    3 axis remote pendant MACH3 for CNC router engraving machine with wire for Mach3 | eBay
    It looks like it would fit the bill for me, but I am just curious if there are any problems anyone has run into with it. $130 is a moderate gamble, but good luck getting support or returning it to China if you have problems.
    Jason
    RPC Electronics, LLC - www.rpc-electronics.com
  1. Hand wheel on 1842
    By Farmers Machine in forum CamSoft Products
    Last Post: 04-13-2010, 11:28 PM
  2. hand wheel dmc 63V not active
    By wilos in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2010, 06:59 AM
  3. Hand wheel
    By Chriss F in forum CamSoft Products
    Last Post: 02-04-2009, 11:30 PM
  4. Hand Wheel / Motor Damper
    By ZigMan in forum Joes CNC Model 2006
    Last Post: 09-11-2008, 07:03 PM
  5. Hand wheel is intermittant
    By chipsahoy in forum Fadal
    Last Post: 03-12-2006, 07:12 PM
