586,655 active members*
2,426 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704. Strange noise coming from the head.
    Apr 2011
    I'm getting a somewhat random knocking noise coming from the head of my G0704.
    I can hear it at the upper end of the low speed range, but it's most obvious when I shift into the higher speed range and run up to max. speed.
    It sounds like maybe teeth not meshing properly, or maybe something loose on a shaft. Hard to tell. It's intermittent.
    I can hear it above the background motor noise but I wouldn't say it's particularly loud. I am concerned that it could lead to bigger problems so I'd like to figure it out before I damage anything.
    I've been using the mill and it seems to be performing well. I'm getting good finishes. There's no slop in the spindle so I'm guessing it's not a bearing noise.
    I've studied the diagram in the manual but I think I'm going to need to pull the head apart to get to the bottom of it.
    Anyone have any experience with this kind of noise on their machine?
    Thanks for any help on this.
    Alistair.
    There is some clearance between the splines of the spindle and the splines of the 2 gear assembly, part #'s 206 ans 246 in the parts manual.
    This is how power is transferred to the spindle and allow quill movement.
    It can rattle at times but isn't anything to worry about.
    This is likely the cause of the noise, it's not uncommon.
    Hoss
    Apr 2011
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thanks Hoss. The word rattle describes it exactly. When I grab the spindle by hand and turn it back and forth in quick succession I can feel the lash that you mentioned. I figured that was normal and was actually wondering if that might be the source of the noise. It makes sense that it probably is.
    Sounds like I can just keep on machining, which is good to hear.
    Just for future reference, can anyone point me to a thread that details head dis-assembly? I figure I'll need it at some point. I'm interested in knowing if there are any specialty tools required, or any pitfalls that I need to be aware of when taking it apart.
    Thanks again.
    Alistair.
    I worked with Michael in changing his spindle bearings starting here and it shows a couple wrenches
    that can be made to help with removal.
    http://www.cnczone.com/forums/bencht..._my_x2-20.html
    Pics below of the upper spanner wrench I made.
    These couple videos show how to remove the spindle and intermediate gears.
    [ame=http://www.youtube.com/watch?v=hP-XvbV7Pc4&feature=plcp&context=C445fd85VDvjVQa1PpcF Mgf1pRyc2Rt2yha5my4NNIEpBOlX3ZjD8=]G0704 Spindle Bearing Replacement - YouTube[/ame]
    G0704 intermediate gear removal.MP4 - YouTube
    Hoss
    Attached Thumbnails Attached Thumbnails G0704 spindle upper spanner wrench.jpg   IMG_5171_800x600.jpg
    Apr 2011
    Hoss
    That's very helpful.
    Thank you.
    Alistair.
  1. How do you remove the head on the g0704?
    By Xnaron in forum Benchtop Machines
    Last Post: 01-23-2012, 12:14 PM
  2. New Tormach with strange Zaxis noise
    By hall6ppc in forum Tormach Personal CNC Mill
    Last Post: 08-28-2011, 06:25 PM
  3. X2 Spindle Head noise.
    By spaceballs_3000 in forum Benchtop Machines
    Last Post: 06-10-2008, 03:22 PM
  4. Bridgeport 2J head noise
    By jbongiov in forum Bridgeport / Hardinge Mills
    Last Post: 02-25-2008, 02:54 AM
  5. loosing steps & strange noise
    By BobF in forum Mach Software (ArtSoft software)
    Last Post: 12-02-2007, 05:01 PM
