587,045 active members*
3,008 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Hex Milling Issue
    Jul 2011
    4
    Hex Milling Issue
    Hello there
    I am using mastercam X4 and I am trying to mill a hex on a part using the C-axis of a lathe. I am using Cross contour and it mills the hex, The tool just keeps running past the face. Here is a screenshot of what is happening during backplot.
    When I set up my chains I select the face to be milled and it keeps taking the mill into the shoulder.
    Thank you for any help.
    Dec 2008
    3122
    You only select the partial chain, not a rectangular profile
    try picking only the contour (line) that you want the tool pass beside ie the line along the back edge
    when the "Chaining" dialog box appears, select "Partial"
    - pick the starting entity, it will give a green arrow ( start of chain), & a red arrow ( chain end), you then follow the prompts on the top of the graphics screen ie pick last chain ( if you want it to go further to a certain position, & then at any branch points ( where there is a choice of path that you have to make ))
    Jul 2011
    4
    Thank you, that fixed that issue. Now the issue is the path is being generated from the center line of the tool which is taking off undesired material. Is there a tool offset for this or is there an option to adjust the cutting zone.
    Dec 2008
    3122
    Quote Originally Posted by yz85608 View Post
    Depends on your machine control
    "Wear" ouputs a tool centerline path, and typically has a zero offset placed in the m/c control
    "Control" outputs the path on the side of the tool, and requires an offset to make the tool stand off that path by the tool radius which is placed in the m/c control
    ( do you have "Simulate Cutter Comp" ON in backplot ? )
    Jul 2011
    4
    Yes cutter comp is set to on. Although on backplot under path 1, this is what I have.
  1. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  2. SprutCAM 7 Milling Issue
    By Pat_IS in forum SprutCAM
    Last Post: 07-16-2010, 01:00 AM
  3. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
