587,072 active members*
3,052 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet 999 Alarm A
    Feb 2011
    Just wondering if anyone had any idea on the cause of this alarm. The alarm number on the SDU is 34 which isn't listed in the book I have. on the display the alarm is listed as 999 Alarm A Spindle 1.
    Jan 2009
    74
    This is a voltage flutter alarm. This is typically caused during the deleration of the spindle. This is caused by the drive trying to push power back up the incoming power lines and not being able to. Check all the connection (fuses, breakers) for loose connections and check the voltage at the breaker. If the voltage is climbing when stopping the spindle then this is a problem on the power lines incoming. If there is not change then this could be a bad drive unit, so drives this alarm (warning level alarm) can be masked.
    Oct 2009
    119
    Hi my freind
    Same Alarm on
    my LR 15 machine. How did you solve this problem
  1. Okuma Cadet Software
    By ryanh114 in forum Okuma
    Last Post: 02-02-2023, 11:51 AM
  2. Okuma Cadet OSP700 alarm 1055-20
    By b1apt in forum Okuma
    Last Post: 05-29-2022, 02:15 PM
  3. OKUMA CADET MATE
    By Antonio Arguijo in forum Okuma
    Last Post: 10-09-2011, 02:26 PM
  4. Okuma Cadet Spindle Where to get one
    By Gary Emig in forum Want To Buy...Need help!
    Last Post: 02-17-2011, 12:17 AM
  5. Okuma Cadet Graphing
    By Kart 34 in forum Okuma
    Last Post: 01-30-2008, 04:05 PM
