586,847 active members*
2,350 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Router Bits and EndMills: Pictures, Descriptions, and Uses
Page 14 of 15 412131415
Results 261 to 280 of 290
  1. #261
    Sep 2011
    1183
    Re: Router Bits and EndMills: Pictures, Descriptions, and Uses
    Thanks Louie I will check them out.
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  2. #262
    Mar 2005
    109
    What would be a good bit to surface (facing) acrylic? I need to skim off 1.5 mm.
  3. #263
    Apr 2009
    5516
    Quote Originally Posted by ifeliciano View Post
    Best tool for acrylic is MCD (monocrystalline diamond) but it's uber-expensive. PCD is good... still expensive. Have to polish afterwards...
  4. #264
    Mar 2005
    109
    Quote Originally Posted by louieatienza View Post
    Ouch!. $150.
  5. #265
    Apr 2009
    5516
    Ouch!. $150.
    That's a cheap one...
  6. #266
    Sep 2011
    2
    My 4'x8' table has a Bosch Colt motor (1hp, 16,000 - 35,000 rpm, 1/4" collet). I have been cutting wood with it and would now like to cut some thin mild steel sheet (< 26ga) and some 6061-T6 aluminum sheet (< 0.040) with it.
    What bits should I use (specifically)?
    What rpm?
    What feed rate?
    The table doesn't have a vacuum surface so I like to use down-cut bits to keep from lifting the sheet.
    Thank you for your time,
    Dave
  7. #267
    Apr 2009
    5516
    Quote Originally Posted by davecove View Post
    What rpm?
    What feed rate?
    Dave
    I think for steel, you may have issues with the too high a spindle speed and not enough power. For the 6061, I have some parameters listed in the first couple pages (and in the descriptions in the videos), and I'd use a single-flute spiral O.
  8. #268
    35538
    These bits are made for cutting steel
    https://www.toolstoday.com/cnc-route...end-mills.html
    You're going to need to take really light passes, and keep it lubricated.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  9. #269
    Sep 2011
    2
    My first project is cutting decorative shapes out of 31ga galvenized steel roofing. Do I still need to lubricate? Or just watch my feed speeds?
    Dave
  10. #270
    Sep 2011
    1183
    I would lubrication.
  11. #271
    Aug 2011
    107
    Hopefully this is a quick one for a guru..
    Buddy needs 3/16 acrylic cut with a 20deg edge. He has given me a 20 deg, tapered endmill, 3 flute. At the tip it is 0.125" with a 0.500" depth/cutting edge
    https://www.mcmaster.com/#8936a971/=1ckjmzx
    What would be a good starting point for Feed and Spindle RPM (I'm using Bosch 1617 router). He really hasn't given me much scrap for test cuts so I would like to at least get in the parking lot, if not the ballpark before I test.
  12. #272
    35538
    I would rough cut it a little oversize with a 1/4" 1 or 2 flute upcut, to provide clearance for the chips. Otherwise, you'll likely get a lot of melting.
    Set the router to it's lowest rpm, and somewhere around 100ipm.
    Gerry
  13. #273
    Feb 2016
    286
    I had some aluminium profiling and pocket to do in 1/8 alu. For this I usually use a yonico 31011-SC 1/8 cutter for or Onsrud 63-610 o-flute when I need better surface finish.
    I decided to give a try to HRC tools single flute cutters since I'm using their spot drills and chamfer cutters since one year and they do a decent job. I ordered two of their 3.5mm, 10mm LOC cutter. It is about the same price as Yonico and half the Onsrud.
    First, one is really 3.5mm the other is a couple thou off more like 3.4mm... Not a really good start.
    For pocketing, it does an ok job when climb cutting but seems to tears material instead of cutting it when doing conventional cutting. A first for me...
    When profiling it makes the same sound as a dull cutter and I ended up with welded aluminium on the cutters. 30 bucks wasted.
    I took an old Yonico to finish the job and I did manage to finish the job even if the cutter was a little bit dull.
    The moral of this story, stay with trusted brands.
  14. #274
    Nov 2019
    3
    I have to say, I appreciate this thread. However, the sticky really makes it seem like its most useful if one already has some idea what they're looking for. Unfortuantely, I don't.
    I'm just getting started, but I'm having a very hard time determining the correct bit for a project. For example, I've got this coaster here: https://easel.inventables.com/projec...Xd0LYBqL2CghEg
    Should be pretty simple. But, unfortunately, I can use 60 or 90 V-bits and it gets close to usable - some of the letters are still a bit deformed. If I try a ball-end, I get total garbage - a circle with some blobs.
    I've got a 10-degree v-bit that might work, but the estimated time is more than 50 hours, which is obviously nuts for a 4x4 coaster.
    Can anyone offer any suggestions here?
  15. #275
    Sep 2011
    1183
    Hi what CAD and CAM software are you using and what machine are you using?
  16. #276
    35538
    Looks like it's just pocketed. In that case, use the largest straight bit that will give you the detail you need in the letters. This may require a very small bit, which can take a lot of time. You could also use a larger bit to remove most of the material, and a small bit to clean up the letters.
    Gerry
  17. #277
    Apr 2009
    5516
    Quote Originally Posted by Merijeek View Post
    In VCarve, you can select a flat area tool to clear the field, this looks like it can be up to a 1/8" flat endmill. The finishing toolpath would be with your v bit. If you don't have VCarve, you probably can do this using a flat endmill, leaving half the diameter of your v bit at final depth along the sides, then do a pencil trace with the v bit... but that would leave tiny islands that you'll have to manually touch up. Point is, you need CAM that allows what we call "rest machining" so you can clear the field with a larger tool.
  18. #278
    Nov 2019
    3
    Quote Originally Posted by LouF View Post
    I'm using a BobsCNC E3, and the software I've tried has been Easel. I've messed with Vcarve a bit, but only the free version so far, which isn't worth a whole lot.
  19. #279
    Nov 2019
    3
    OK, going with that advice I've run a simulation with a 1mm cutting endmill followed by my 10-degree v-bit. Total time looks to be about 2h30m. Which is certainly a move in the right direction. Now I need the new bits to actually arrive.
  20. #280
    Feb 2016
    286
    What would be a good cutter to cut pockets and chamfer in Trespa phenolic panels on my router?
    Do downcut or upcut makes a difference?
    My spindle goes from 7 500 to 20 000 rpm; whats are the base feed and speed?
    I have from 1 to 4 flutes cutters.
    I know that diamond coated would be best but I'll have to stick to HSS or carbide.
  1. Router bits and Endmills guide?
    By nikostis69 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-13-2011, 12:05 AM
  2. Which router bits/endmills to get??
    By margni74 in forum DIY CNC Router Table Machines
    Last Post: 09-05-2009, 03:51 AM
  3. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  4. Endmills and Router Bits, Oh My!
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-10-2007, 07:55 AM
  5. 1mm endmills/bits
    By johnm99 in forum CNC Tooling
    Last Post: 09-17-2007, 06:24 PM
