586,555 active members*
3,537 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Router Bits and EndMills: Pictures, Descriptions, and Uses
Page 15 of 15 5131415
Results 281 to 290 of 290
  1. #281
    Question Re: Router Bits and EndMills: Pictures, Descriptions, and Uses
    I have a DIY CNC router that is speed limited running 5mm lead ball screws. So plenty of torque limited speed. :tired:
    My immediate need is to cut plywood up to 3/4", both softwood and hardwood including marine grade.
    My router is a 2-1/4HP with a min speed 8000rpm. So from my understanding I'd probably want a 1/4" single flute carbide cutter to maintain a decent chip load.
    Is my understanding correct?
    Second, I searched Ebay for Onsrud and a lot of single flute cutters come up labeled for aluminum. Are these suitable for plywood and other woods?
  2. #282
    How fast can the machine actually cut? At 8,000 rpm, you're fine to use a 2 flute bit.
  3. #283
    Not sure. I hope to power up for the first time this weekend.
    Embarrassingly, if my calcs are right, ~50-60 ipm. If I had 1/2 the inductance and twice the lead I'd be 200-300 ipm territory. For the time being I have to make due with what I have.
    With that in mind would you still recommend 2-flute cutters?.
  4. #284
    My understanding is with a compression bit you need a depth of cut that engages the down spiral with the top surface, So for example a 1/4" tool, 3/8- 1/2" (~7-10mm) deep cut.
    For Birch plywood, would you recommend using a compression bit on a DIY hobby machine?
  5. #285
    Yes, I'd still use a 2 flute bit.Unless you can easily find inexpensive single flute bits for wood. The "O" flute bits for plastic and aluminum will work OK for wood, but they tend to be expensive.
    I don't use compression bits on my DIY machine, because I don't really need them. They work best when making one full depth pass. If you make multiple passes, you'll wear out the tip a lot faster.
  6. #286
    I'm looking for an economical spoil-board surfacing bit/cutter. I came across this one.
    https://www.grizzly.com/products/Gri...xoCPaAQAvD_BwE
    Can I do better than that bit for similar money? I have a 48x48" table and 2Hp router so I was thinking 2' cutter 1/2" shaft.
  7. #287
    Feb 2005
    829
    I use this one.
    https://www.amazon.com/Magnate-Surfa...222962&sr=8-15
    But that grizzly looks decent, and it is cheap.
  8. #288
    Any straight bit will work, and you probably won't find a 2" bit for less than $25.
  9. #289
    For 3/4” plywood you want to use a 7/8 or 1” long bit correct?
    Or does a typical 3/4” spiral up or down cut bit have enough edge for cutting and chip clearing?
  10. #290
    Yes, 7/8 or 1".
    Since most plywood is undersize in thickness, you can usually get away with a 3/4" bit, but a little longer is better. The flutes on a spiral bit extend beyond the cutting edges, so that's not an issue.
  1. Router bits and Endmills guide?
    By nikostis69 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-13-2011, 12:05 AM
  2. Which router bits/endmills to get??
    By margni74 in forum DIY CNC Router Table Machines
    Last Post: 09-05-2009, 03:51 AM
  3. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  4. Endmills and Router Bits, Oh My!
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-10-2007, 07:55 AM
  5. 1mm endmills/bits
    By johnm99 in forum CNC Tooling
    Last Post: 09-17-2007, 06:24 PM
