586,145 active members*
3,775 visitors online*
    Sep 2009
    anaheim automation
    Hello All
    I bought a used digital tool router that has a DPF41BB1 anaheim automation drive.Im wanting to run it with Mach3 but I dont know how to wire it.So im looking for any diagram and any help I can get on it.
    Thanks Jeff
    Sep 2009
    Any help would be great!!
    Jan 2011
    welder,
    It is very simple to wire it to a computer. You will need a computer with a parallel port. Then, route the wires like this:
    more info here: http://seriss.com/opcs/install/anaheim.html
    that image shows it for two motors, but you can continue using the same parallel connector for the other two motors. Just put the other two sets of wires in the next available pins.
    Remember how you routed your pins and then configure Mach3 accordingly.
    I have never configured Mach3 before (I use EMC2), but the operation should be very similar.
    There are three basic things the computer will need to know to move each motor:
    1. Enable/Disable pin
    2. Direction pin
    3. Steps/Clock pin
    You will need these for each motor. Keep in mind that the enable pins can be bunched together and the ground pins can be bunched together as well (see image above)
    Sep 2011
    We're in the process of restoring a CNC Router based upon this exact controller. Does anyone have a working Mach 3 or EMC2 config file they're willing to share? We've got the pinouts from the controller and it matches the below diagram. Unfortunately the step and direction pulse width and setup timing are still a stumbling block for us.
    thanks for any pointers!
  1. anaheim automation?
    By cwpeters in forum Controller & Computer Solutions
    Last Post: 04-20-2010, 11:38 PM
  2. Anaheim Automation drive pack???
    By SSN Vet in forum Stepper Motors / Drives
    Last Post: 02-04-2009, 03:33 AM
  3. alternate to anaheim automation
    By caseworks in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 11:53 PM
  4. anaheim automation dpf65003 Drive pack
    By Aiko in forum Stepper Motors / Drives
    Last Post: 08-17-2007, 05:35 AM
  5. Anyone use Anaheim Automation MBC10101 drive?
    By RobbieBeggar in forum Benchtop Machines
    Last Post: 12-21-2006, 07:25 PM
