586,500 active members*
1,654 visitors online*
Thread: Fadal 4020
    Mar 2012
    Fadal 4020
    Hello friends!
    I´m new here, located in Austria and since a few mounths user of a Fadal 4020 with 88HS control system (and untrained such in english than in programming 88HS) and ask for help!
    In using a circle pocket cycle I cannot find the possibility to mill the pocket in steps! It always mills the fully depth in 1 cycle!!! This is not usable for a Pocket with 9mm Dia and 30mm depth.
    The problem is always the same in the other pocket cycles and the drill / mill function.
    Please, can you give me an idea to crack the trouble?
    With best regards
    Guenter
    Sep 2009
    33
    Feel free to call Douglas Salguero, 818-727-2100 or email at [email protected] to answer any Fadal programming question. He has been the senior Fadal programmer for the factory for over 20 years and would be happy to help.
    Pat Grantz
    Director of Operations - PowerInterface iMPACTiq
    Apr 2005
    1194
    You need to add a subroutine and a z depth increment each time you bore. Or get a CAD system (best option)
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Apr 2012
    Smile 9mm dia 30mm deep
    Guether.
    Move to center of hole with A 5mm dia e/mill then
    G1Z0F2.0
    G91Y2.0
    G3J-2.Z-1.L30
    J-2.0
    G1Y-2.
    G90G0
    Z75.
    Chris
    [email protected]
  1. Fadal 4020
    By LatheCrasher in forum Fadal
    Last Post: 02-17-2012, 03:23 AM
  2. Fadal 4020 mm/um in MDI
    By hartan in forum Fadal
    Last Post: 12-20-2011, 10:50 AM
  3. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
  4. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  5. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
