Originally Posted by
effimos
you don't need to seperate per type of switch like 'home' and 'limit' but you need to seperate per axes 'x' , 'y' and 'z' (and on my router the tooltip = my z-limit).
Actually, both methods will work. There's not really too much benefit in having limit switches separate from your homing switches unless you're not homing to a limit. So, you can wire all 6 switches in series to a single pin for homing and limiting.
Once you have a homing arrangement though, you'll find that soft limits in Mach 3 work pretty well.
Finally, your tool touch thing might not work if your tool has proper grounding. Better to wire the touch plate to an input and have the tool grounded. If your router is insulated such that the bit isn't grounded, your arrangement will work.
-Andy B.
http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
