586,898 active members*
2,831 visitors online*
Results 1 to 16 of 16
    Jun 2007
    44
    NV5000 optional stop does not work
    When I press optional stop (OSP) button machine does not stop after tool change, it continues to next tool and so on. Do I need M1 or OSP should stops without M1? Is there any parameter or setting to enable OSP?
    Feb 2009
    6028
    Optional stop is M01. All machines are like this. No way to stop after a tool change without it.
    Aug 2011
    2517
    no no, on the newer Mori's you can telepathically tell it to stop and it just does it if the switch on the panel is pushed in. hehe
    Feb 2009
    6028
    Quote Originally Posted by fordav11 View Post
    So, your saying "use the Force Luke"?
    Aug 2011
    2517
    forgot to add, it only works if your name is Luke.
    funnily enough our local Fanuc repair guy is named Luke.....
    Nov 2011
    40
    Mori Seiki uses sub program for tool change if it is newer machine like the one i am working on.
    It is O9001 and all you need is to edit that program. It is missing M01. If you still haven't found the solution let me know i think i can help you with that.
    Example:
    O9001(ATC)
    M5
    M9
    G0 G91 G30 Z0
    G0 G91 G30 X0 Y0
    M19
    M6
    G90
    M01
    M99
    Feb 2009
    6028
    Quote Originally Posted by IfeCro View Post
    Example:
    O9001(ATC)
    M5
    M9
    G0 G91 G30 Z0
    G0 G91 G30 X0 Y0
    M19
    M6
    G90
    M01
    M99
    No, someone added that macro.
    Nov 2011
    40
    Yes that macro is added by company that sold our machine i do not know how are tool and palette changes done elsewhere but i have it like that. And also when our last machine was delivered M01 was missing from that macro.
    My company have arround 60 Mori Seiki machines (NH,NT,NL,NV) and on all of them have macros like this one.
    I guess that depends on reseller (I am from Croatia and machines are from company in Italy)
    Feb 2009
    6028
    It's normal to add the macro. I put them in on delivery here. I could tell that must be a nh macro. G30 isn't used on the verticals for tool change.
    Nov 2011
    40
    Yes you're right it's from NH and i will take your advice on M19 very good tip.
    And who are you sir you seem to know Moris like no one i have ever met.
    I might have a few questions if that is ok. I am only operator nothing fancy
    Feb 2009
    6028
    Just an ex old service guy.
    Feb 2009
    6028
    And don't bother with the m19. I forgot, those machines will wait for the m19 finish signal before movement.
    Feb 2009
    6028
    Oh, and don't bother with the m19. I forgot those will wait for a m19 finish signal before movement.
    Feb 2009
    6028
    Feb 2009
    6028
    Feb 2009
    6028
    Dam tapatalk sometimes.....,
  1. M01 Optional Stop not working
    By erd39030 in forum Fanuc
    Last Post: 02-03-2019, 06:56 PM
  2. How to activate the optional stop
    By dingo0722 in forum Haas Mills
    Last Post: 01-25-2011, 04:16 PM
  3. Replies: 2
    Last Post: 12-15-2009, 07:09 PM
  4. Mo1 Optional Stop
    By a1moldmaker in forum Fadal
    Last Post: 04-09-2007, 03:08 PM
  5. Avoid Loading New Billet On Optional Stop
    By Joey in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-19-2007, 02:55 PM
