586,403 active members*
2,872 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 conversion parts list & Questions
    Dec 2007
    13
    Hey guys, I am tooling up for my conversion of a G0704 which will be on order in the next day or so along with Hoss's plans.
    I wanted to post up my parts list and see if you guys had thoughts on other things I should get or know of any good deals going on that I should jump on.
    Thanks for your help,
    -Marq
    Parts from Grizzly:
    Anyone have a discount code for Grizzly? I ordered a catalog but dont think it will be here in time before I order.
    1) G0704 mill with stand -- $1200
    2) R8 collet set -- $74
    3) Parallel set -- $29
    4) Clamping kit -- $43
    5) R8 collet rack -- $10
    Electronics:
    1) I have 2 e-stop switches from old projects
    2) Also have shielded wiring for stepper motors
    3) I will be building up a used computer -- $250 (with mach 3)
    4) Thinking of going with the Hoss HD digital package -- $650
    Is the more expensive BOB with the charge pump worth the extra $$$$
    5) [ame="http://www.amazon.com/Neutrik-Pole-Male-Cable-Conn/dp/B000BDDOOK/ref=pd_sim_sbs_p_2"]Enclosure Motor connectors[/ame] -- $4 each
    6) Limit switches (thinking I would get the same ones as Hoss)
    Ball Screws:
    1) I am looking at getting Roton ball screws with nuts from CJA masterworks without the ends machined -- $270
    2) I also found these C7 grade ball screws
    which ones would be better for the 0704?
    Which one would have better clearance for the ball nut on the X stage?
    Anywhere else I should look for ball screws? I have read to many horror stories from the ebay ones so I am going to steer clear.
    How much are the oversized ball's to reduce backlash?
    Mechanical Items:
    1) Shaft couplers (thinking I would order them from McMaster but haven't looked around yet)
    2) Aluminum Stock for motor mounts (still haven't priced it out)
    3) Angular contact bearings for ball screws (still need to search on this one)
    Tooling:
    1) 4" Glacern -- $250
    2) I need a decent starter dial indicator set, any suggestions? (I have a set of digital dial calipers)
    3) My work has a full CNC shop and one of the machinist offered me his whole drawer of used endmills, taps, and other tools.... this should get me by for a while
    Hey Turbogt (Marq),
    If you can turn your own ballscrews as I take it you can, you can get the Roton screws and nuts directly from them
    for about $190 per my plans.
    5/8 X .200 Right Hand Recirculating Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
    The Homeshopcnc C7 screws are akin to the chinese screws from linearmotion many use as well as in my plans.
    They'd be a little tougher to machine yourself but not impossible.
    This DTI is a pretty decent import.
    .030"/0.6mm LARGE .0005"/0.1mm DIAL TEST INDICATOR | eBay
    or this set from LMS.
    LittleMachineShop.com - Inspection Kit, 6-Piece
    Sources for the mechanical items are also in the plans.
    Hoss
  1. The UHU parts list, questions and improvement.
    By vroemm in forum UHU Servo Controllers
    Last Post: 09-08-2022, 05:55 AM
  2. What parts list for G0704 conversion?
    By bogiestl in forum Automation Technology Products
    Last Post: 12-27-2011, 03:26 AM
  3. Parts list & Basic Tooling for G0704 Conversion?
    By j.steensen in forum Benchtop Machines
    Last Post: 07-29-2011, 05:32 AM
  4. Trying to Finalize Parts List for Conversion
    By imprez55 in forum Benchtop Machines
    Last Post: 07-08-2009, 01:24 AM
  5. A little lost... How does this X2 conversion parts list look?
    By JMcDonald in forum Benchtop Machines
    Last Post: 05-27-2007, 01:04 PM
