586,817 active members*
7,718 visitors online*
Results 1 to 20 of 20
    Nov 2011
    LaserCut losing steps?
    Hi All,
    I'm trying to run a very long job... approximately 500 small parts. The process is to cut all of the holes, and then come back on a second pass and do the cutouts. I have each one set up as a different color in LaserCut.
    Once all the holes are cut (1000), it starts doing the cutout pass. The farther into the job it gets, the more the cutout skews from where it should be on each part.
    If it were my CNC machine, I'd think it was losing steps. I tried turning the acceleration down in the machine settings.
    Any ideas?
    Aug 2005
    91
    No idea but I hope you find the answer soon.
    It must be loosing a fair few steps to become visible, is it out by eye or are you measuring them?
    Nov 2011
    Quote Originally Posted by jasonharris22 View Post
    You can see it in the part. Now, the machine cuts 1000 holes, then 500 little lines, so whatever little issue there may be is multiplied 1500 times before it even starts the cutout.
    My interim solution was to set up the job in blocks... cut the holes in a section, cut out the parts, then move on to the next.
    I'm sure it's a config thing... probably a very simple fix.
    Apr 2010
    Sounds like the stepper motors are not set up correctly. Is there any way to set up your steps per inch ?
    Nov 2011
    It does seem like a stepper setup issue, but I'm leaning more towards acceleration issues than steps per inch... I'd think if the steps per inch were off, it should still be repeating the cuts, they'd just be the wrong size.
    I tried decreasing acceleration, and probably need to turn the rapid speed down as well. Right now I'm so far behind on this parts job that I don't have time to experiment with it. I'm not even sure that the changes I made posted to the machine? I had it plugged in with the USB, and the computer was able to control it, but I don't know if there's something I have to do to post or reflash the DSP.
    We ran all night with the jobs broken into smaller clusters... cut a section of holes, cut the parts out, cut another section, those those parts out. It's just as fast, but requires a little more setup. Still something I'd like to resolve.
    Apr 2010
    Personally I have never had a problem with acceleration making the part not cut right, I have had acceleration make the steppers loose a step or two then of course the part is toast. What if you cut a series of round holes, is the first one accurate ? (round) or does it just get bad when your four or five holes down the line ?
    Feb 2005
    469
    If you make changes to the machine settings in LaserCut, they won't take affect unless you re-download the config file to the laser. You should hear a beep after a successful download to the machine.
    Nov 2011
    Quote Originally Posted by bundysax View Post
    They're all round, and the correct size, however, after I cut a few hundred and start the next process, the second pass is not aligned with the first cuts.
    Basically, if I cut 1000 circles, and then tried to have it come back and cut them all a second time, it would be cutting 1/8" to the left of the original set, and get progressively worse as it went.
    Aug 2005
    91
    Quote Originally Posted by Asynchronism View Post
    1/8th" (3.2mm) is a hell of a lot. I don't know what the gearing is on these things but to achieve the dpi they have I would think that is a hell of a lot of steps it must be loosing to get that far out.
    Makes me think it is something else, I have no idea what though, maybe a software bug, if it was Gcode I guess you could tell by seeing what the software is telling it to do but I don't know anything about the lasers equivalent.
    Apr 2004
    475
    Basics to try
    To figure out it it is losing steps, I think your best bet it is push the speed of the machine, even if that means just marking a scrap piece and seeing if the skewing gets worse. And, of course, see if slowing it down makes it better.
    Next thing to try would be slowing down the acceleration, as it could be losing steps there too, although less likely.
    Was the problem is just one axis or both?
    Nov 2011
    I found the download button and dialed back the rapid speed and acceleration a little. I still need to get this job out, but I'll test as I can... if not, I'll run a full test next week.
    Apr 2004
    475
    Rapid speeds.
    Yes, I think for the testing, setting the rapid speed lower and to match the "stress test" cutting speed would be a good idea. I would probably first set the acceleration back to the factory settings, keeping those issues separate.
    Nov 2011
    Just ran a few hundred with the acceleration and rapid speed dialed back a hair, and the parts are flawless. Thanks to all for the ideas.
    On the positive side, the machine has been cutting (literally) non-stop for the last 105 hours without complaint, and, if all goes well, it probably will for another 48-72 before we wrap up the run we're doing. Not bad for its first week on the job...
    Apr 2010
    Glad to hear your problem is fixed, did you dial the speed back from the factory settings ? what is your final setting.
    Sure hope I can get a job that lets me run my laser for 100 hours non stop !!
    Nov 2011
    Factory was 70 for acceleration, 50 for the rapid. I changed it to 60/45. I can't really see and difference in job times, but it's repeating now.
    Be careful what you wish for... after that much time, everything has ABS residue all over it, we all stink, shop stinks... the machine is clearing the smoke, but the stuff just stinks and is gooey.
    Sep 2011
    296
    Hi, Dave,
    You are always here but not online of Skype I'm waiting for you there all the time.
    I have asked our technician about your problem. I need to send some files to you online and tell you some ways for testing first.
    When you are free, call me~
    Sep 2011
    296
    Hi, Dave,
    We studied your syscfg file, and found lots of problems. I have modified your setting and tested on our own machine. It seems Ok now. You just need to use the new syscfg file to cover your former ones. It is an easy way.
    Mar 2011
    I got exactly the same problem while cutting many small parts. There was a shift only on the Y axis.
    First I reduced the speed to solve the problem temporary. But after some more cuts, the problem came back.
    I thought something was "tired" and I checked the mechanical components, changed the stepper motor and the motor driver. Without success.
    Fortunately I found this thread and it give me the idea to restore the syscfg file I got with the installation CD. And like a miracle, everything worked well as before.
    I want to understand what happened since I never touched to the configuration except for the pulse units (fine tuning for more precision). The difference I found between the syscfg file are these lines (added at the end of the bad file):
    [AddInOutLead]
    InType=0
    InLineLength=2.0
    InAngle=90
    OutType=0
    OutLineLength=2.0
    OutAngle=90
    StartDirType=0
    CloseType=0
    OverLapLength=0.0
    Valid=0
    [FileFormatCfg_PCB]
    MaxCurveNumber=1500
    nCoordinateFormat=00
    nIntegerNum=3
    nDecimalNum=4
    nUnitType=0
    nCoordType=90
    PointSpace=3.0
    Do you know if these lines are the problem and how they appeared ?
    Nov 2011
    Wish I did... I never fully sorted out what all of the things in that file relate to... either in reality, or in the software settings. Have you tried reducing speed or acceleration?
    Mar 2011
    Yes I began to work with a 20mm/s setting without problems. When **** happened I tried to reduce the acceleration without effect. I reduced the speed to 12mm/s, it worked well again but only for few hours.
    Since troubles were going worse, I was sure this was a hardware problem.
    I'm really surprised to have solved it by reloading the genuine syscfg file, that doesn't make any sense
  1. Losing Steps
    By dgroulx in forum Stepper Motors / Drives
    Last Post: 12-23-2011, 09:28 PM
  2. Losing steps
    By tjs88yj in forum Viper Servo drives
    Last Post: 02-25-2010, 12:31 AM
  3. Losing steps in Z - need help
    By zeeway in forum DIY CNC Router Table Machines
    Last Post: 02-13-2010, 02:51 PM
  4. Losing Steps?
    By finishlinewrx in forum DIY CNC Router Table Machines
    Last Post: 07-16-2009, 12:21 AM
  5. Losing steps - WHAT IS UP?!?
    By Sporqster in forum DIY CNC Router Table Machines
    Last Post: 04-27-2006, 03:50 PM
