586,103 active members*
3,859 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > to much slag from CNC plasma cutting
Results 1 to 7 of 7
    Aug 2011
    When I cut 1/4 inch or thicker the drop of slag on the bottom is significant. I have a water table and am using a 625 tomahawk plasma. How do I reduce the amount of drop? I have adjusted the amps, speed, air flow, talked to the table and plasma mfg. So far no clear suggestions on how to reduce the drop slag.
    Jan 2011
    I'm not super-familiar with the Tomahawk plasma, but from what I've read it's not a very powerful machine, so you're probably limited to cutting slower than what you'd need to, to minimize the dross.
    For comparison, I cut 1/4" at 45 amps, and 50-52 IPM with great results. (using a Powermax 45)
    Carl
    Jan 2008
    2247
    You probably have a Torchmate table with the Lincoln Tomahawk. Best bet is to work with Torchmate tech service. If the Tomahawk cannot cut dross free on 1/4".....maybe there is an issue that is covered by their warranty?
    I use a Hypertherm Powermax45......dross free to 1/2" without issues. I just use the specs exactly as listed in the operators manual....it is used on a Tochmate table as well.
    Jim
    Quote Originally Posted by CarltonCNC View Post
    Aug 2011
    What amperage do you cut 1/4 inch at? What is the max amperage of your plasma cutter?
    I have talked to thech support and had the Lincoln guy out to look at the system. No solution at this time.
    I appreciate your suggestion.
    Jan 2008
    2247
    These cuts are done with either a Hypertherm Powermax45, powermax65 or Powrmax85 at 45 amps. No dross on 1/4"...clean cuts with straight edges. Cut speed is 60 inches per minute. All are on 1/4" steel....no cleanup done.
    Jim Colt
    Attached Thumbnails Attached Thumbnails .250 cuts 001.jpg   .250 cuts 002.jpg   IMG_2421.jpg   IMG_2360.jpg
    Dec 2005
    173
    You could also try lowering the water level in the table a bit as well. If the water is against the bottom of the sheet, it may be causing some of your problem.
    Brad
    Oct 2010
    Those are some very nice cuts Jim.
  1. Replies: 32
    Last Post: 04-13-2018, 12:38 AM
  2. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  3. Precision Plasma LLC 6" rotary chuck for CNC plasma cutting
    By rchacich in forum News Announcements
    Last Post: 05-26-2010, 06:57 PM
  4. Slag Removal?
    By + d in forum Waterjet General Topics
    Last Post: 03-16-2009, 12:26 AM
  5. Vibratory or tumbler for slag?
    By BallisticFab in forum Mass finishing equipment/media/strategies
    Last Post: 03-05-2007, 10:14 PM
