We have an HPR 260 at our bridge fabrication shop. The torch leads (coolant, cut gas, plasma vent, pilot arc conductor) have not been replaced since we bought the machine new, about 6 years ago. This machine is used HEAVILY. Friday the leads on the torch end (going into the metal torch sleeve) failed. Two cut gas lines broken or with holes worn, and coolant supply with a large hole in it. Some of the gas line looked charred, but no evidence of arcing on the metal sleeve. The pilot arc conductor is intact and the insulating tube around it looks fine. We have ordered another lead (25') from Hypertherm (part No. 128784), as well as a Quick-disconnect receptacle which had badly worn threads on the torch end (part No. 220163).
All said, and I hope Jim Colt is listening, does anyone refurbish these leads? The 25' leads are almost 3' longer than needed and all the wear seems to be from the tubes rubbing the metal sleeve as the THC moves up and down. Maybe alittle bit of high temp stress on the gas hoses. Is it advisable to try to refurbish these and save them for back ups? Its only the last 6 inches or so that's been damaged.
