586,475 active members*
3,440 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > im desperate for a solution for my project
    Mar 2012
    im 16 and for my school project i built a 6'x12' table, I used dynatorch drivers and hardware and it works like a charm. Im entering it into an ag mechanics compitition but to show it in the show barn i cant fire up the torch so instead i have a marker apperatus strapped to my torch, the only problem is i cant pick up mid cut so i cant do any crazy designs to really show it off, so if anybody knows any way to solve this problem it would be much appreciated
    Oct 2005
    2392
    Congrats, that's impressive building a 6'x12' torch table at 16 yrs old!
    I suggest you look for a solenoid, there are an electric magnet that can run from 12 volts and will move 1/4" or maybe 1/2". It should be easy enough to drive from your torch software, and you can just connect the solenoid to raise/lower the marker pen. Try an ebay search for "12 volt solenoid".
  1. I am in desperate need of a post !!
    By Blackknight in forum EdgeCam
    Last Post: 05-01-2011, 05:04 AM
  2. I'm desperate !!!...
    By pcasca in forum Mastercam
    Last Post: 01-04-2011, 12:16 AM
  3. HF Mill Need help Desperate
    By rodzilla in forum Benchtop Machines
    Last Post: 12-04-2007, 03:09 PM
  4. Desperate times call for desperate measures
    By lilricky2 in forum Mastercam
    Last Post: 06-14-2006, 02:48 PM
  5. In Desperate Need
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 08-02-2005, 06:55 PM
