my machine has a gear drive for spindle. One gear gives speeds upto 1000 rpm and other gives 1000 and above.
somehow, the gear change stopped working due to some mechanical jamming of lockpin. so an expert changed the K07 bit from 00110000 to 00100000.
this has resulted in spindle working at all speeds but, the speed entred in the program and actual speeds do not match. Actual speed is 240% to 260% more than the entered speed.
can someone tell me if there is any solution to this problem other than getting mechanical problem solved?
