586,481 active members*
3,229 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Programming a Journeyman 250 w/Dynapath Delta 10M/20M Control
    Feb 2011
    I am looking to program a Circle Mill Pocket on our Journeyman 250. Can someone point me to a thread or to someone that may have knowledge for this type of programming? I am looking to use the G7 code, but I have some in depth questions.
    Thank you in advance.
    Oct 2006
    106
    I would have to say the manual is the best source of information on the Circle Mill event.
    A couple not-so-obvious facts:
    Since the center of the circle mill is described in the event, it is not necessary to position the tool to the center of the pocket. Just be aware that the tool will return to the original position after the circle mill is complete.
    You must activate a tool diameter in an M-Function event prior to the Circle Mill event, so that the control knows the diameter of the tool being used. This is necessary when pocketing to determine the proper overlap between passes.
    Although a more recent manual (like a Delta 40/50/60 mill manual) can be used, be aware some variables were added, like starting angle (A, I think).
    Feb 2011
    Activating an M-Function event may be my issue right now. When the quill lowers into position, I receive the following fault message:
    R < Circ+L
    How do I insert the M-Function? I do know G&M code programming and conversational, but this machine has me baffled at times.
    Thanks again.
    Quote Originally Posted by jagardner4 View Post
    Oct 2006
    106
    You can enter an M-Function event (an event type 9) in a block prior to the Circle Mill event. For example, enter the Circle Mill event at N0010, then you can put the M-Function event at N0005.
    Mar 2012
    Quote Originally Posted by Spiderman View Post
    We used to have one of these at my work.Absolutely loved that machine.Too bad they sold it off
    The G7 code during a circle mill event is a full pocket code.
    Do you have a tool number designated at the beginning of the program?
    You must have a tool diameter (mode 6 )
    Also the tool dia must be smaller than the dia of the pocket your trying to cut.
    Any other Q's fire away.I've been programming these for 15 + years
  1. Replies: 5
    Last Post: 05-23-2013, 10:53 PM
  2. Dynapath Delta 20 CNC control
    By gary098 in forum Uncategorised MetalWorking Machines
    Last Post: 12-13-2012, 04:05 PM
  3. Tree VMC 840 with Dynapath Delta control
    By Shane1234 in forum Tree
    Last Post: 07-26-2011, 12:47 AM
  4. Dynapath Delta 20 Programming Manual
    By BugEyedValiant in forum Tree
    Last Post: 01-24-2009, 12:57 PM
  5. Dynapath Delta 20 control
    By Steve A. in forum DNC Problems and Solutions
    Last Post: 08-17-2006, 07:56 PM
