587,006 active members*
3,269 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > holzher promaster 7123
Results 1 to 13 of 13
    Feb 2012
    6
    I need ARTCAM EXPRESS 2011 post-processor configuration file for my Holzher promaster 7123k machine.Its working with CAMPUS 'HOPS' software and sinumerik 810D controls, any help........:drowning:
    Dec 2011
    59
    Have you tried the Holz-Her -Master TC post processor in the post p list?
    if this one doesn't work then
    Contact your reseller, they are the one's that need to take care of it for you
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Feb 2012
    6
    artcam
    hello sir,
    I directly purchased from DELCAM. already informed them. but they are asking another 70 USD for configuration file!:tired:
    Dec 2011
    59
    sounds like a fair price to have a custom postp written & tested for your machine.
    These are editable post so you can also customize an existing one to your requirements yourself.
    Gary
    www.beckwithdecor
    Feb 2012
    6
    hello sir,
    i don't think so. :nono:
    Dec 2011
    59
    So if I come to you and ask you to create a custom file for me then you will do it for free?
    or do you expect to be paid for your time?
    Gary
    Feb 2012
    6
    Hello sir,
    Can you make a configuration file for my machine? how much you need?
    Dec 2011
    59
    firstly most post are created or updated by the machine manufacturer.
    Have you contacted your machine manufacturer to see if they had an updated post already?
    Yes we can create a post for you, but as I charge more than Delcam I would recommend you go back to them.
    Gary
    www.beckwithdecor.com
    Feb 2012
    6
    Hello sir,
    thank you very much for your advice. Artcam express is perfectly working with our WEEKE venture-5 (optimat BHC-550) machine. maybe recent future they will add post for HOLZHER PRO-MASTER. I am also trying..........
    Jun 2012
    I worked on Holz-Her Promaster S machine, very good machine. And I wrote ArtCAM postprocessor for HolzHer machine by myself. We made 3D milling and carving with it.
    Jun 2018
    Gentleman, I've same holzher m/c 7123 running since last 5 years without any problem but I'm having following issue now & can't seems to be finding root cause or solution & really need some suggestion. below is a small description of what's issue.
    when I'm running same programme, somehow I'm getting variation on drilling dimensions ( I'm using only various drills from drilling head on this machine, no routing tools required for my parts) . so let's say I made a part with drilling dimensions of 50 mm on each X & Y direction, I check first part & it's o.k. but when I run production, some how these dimension varies by 2 or 3 mm & it's not consistent variation. some time it happened after 10 parts some time after 50 parts. I've change new programme & same this is happening. so I'm not sure why this variation/ I've change my vaccum pods which seems to be holding parts good. my origin pins has no movement so chances are variation because of pin are nil. do you guys think there is an issue with servo motor ir ....? any suggestion are appreciated.
    Jul 2014
    39
    Re: holzher promaster 7123
    Hello
    I buld PostProcessor for Holz-her Pro-Master and Felder CNC machines, for NX users and Mastercam users.
    [email protected]
  1. Masterwood/Holzher project 316-K Help
    By moultim in forum CNC Machining Centers
    Last Post: 07-25-2020, 09:56 PM
  2. holzher 7123 parameter programming
    By terry10 in forum Commercial CNC Wood Routers
    Last Post: 06-14-2016, 12:18 PM
  3. Holzher Conquest 510 - Metal Cutting
    By atguy21 in forum Uncategorised MetalWorking Machines
    Last Post: 11-01-2007, 03:11 PM
  4. CR Onsrud 145G16 vs. Holzher UNI-Master 7226
    By Jamf2 in forum Commercial CNC Wood Routers
    Last Post: 01-27-2007, 07:51 PM
