586,455 active members*
3,416 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > 5 axis breakout board wiring PLease :'(
Results 1 to 17 of 17
    Sep 2011
    i purchase a 5 axis board of ebay to setup with my geckodrive G201x but not sure how to setup the input up.
    need help please i'll also upload the files that came with it... please i need help:drowning:
    Attached Files Attached Files
    Sep 2011
    Jun 2011
    i wonder how that cheap breakout board handle your drive compare with other BOB..
    Sep 2011
    trying to find a good BOB right now, but i'm looking forward towards buying the pdmx-126 but i was unable to find a good wiring diagram. so I'll have to wait :violin:
    Mar 2009
    533
    You need to get the manual for the G201.
    Then use the GND, DIR, STEP, ENable to the similar inputs.
    Take one axis, say "Y".
    5-AXIS BOB G201
    YN --------------- Power GND
    YD --------------- DIR
    YS --------------- STEP
    YE --------------- DISABLE
    The other axes will be similar.
    What is not clear to me is whether the pulse direction is standardized. i.e. is YE high for enable? Is G201 DISABLE high or low for disable?
    You will need to know the pulse direction for each device.
    I don't have your devices so I'm only going by the data you provided and the G201 manual.
    Sep 2011
    the ebay seller sent me this info,and it worked but the motors speed was slow. so i'm searching for a good BOB for the geckodrive. thanks for the help
    Mar 2007
    2083
    Hi isowe ,
    as far as I can see , the minimum connections you need are
    connect the G201's terminal 10 to the BOB's Ground
    and the BOB's step and direction outputs to the G201's inputs
    the breakout ENABLE outputs are via 1K resistor you will need to test
    to see if this will correctly disable the G201 driver
    John
    Sep 2011
    i'll give it a try today and i'll also post a youtube video if i get the chance
    wish me luck
    Jan 2010
    2141
    Also note that the G201X can accept either a positive voltage or ground connected to the COMMON terminal (your diagram shows a ground connection) - the choice would depend on your Mach3 configuration (Low Active) settings.
    Oct 2012
    9
    do you know what the pins are for mach3? I have the same breakout board, I ordered it off ebay to see how good the board and driver kit was. Right now its a nightmare trying to figure out how to make it run! If I can't get this thing to work I'm just going end up purchasing a c10 breakout board from cnc4pc its the easiest board that I have worked with so far.
    Heres the link if anyone needs a good board CNC4PC
    1943
    Quote Originally Posted by apsara View Post
    The pin definitions for the Chinese BOB are in the pdf manual in post #1 of this thread.
    I have had that same chinese 5 axis BOB on both of my machines and have not had any problems at all. I know the C10 is popular and I am sure it is a good BOB, but I can't see how it can be easier than any other. This one seemed very easy to me.
    Oct 2012
    9
    its still not working for me.
    is the board supposed to be buzzing loudly?
    Jan 2010
    2141
    Uh, no.
    Could it be the relay (the large, black, rectangular object in the lower left in the board photo above) that is making the noise? If you put your finger on the relay, do you feel vibration coming from it?
    1943
    Thats a good thought. if you have the pin assignments wrong you could be sending a step signal to the relay causing it to rapidly latch and unlatch
    Oct 2012
    9
    I have never worked with this board before so don't really know what Im doing with it. I'll snap some pics of the setup and show you guys. I want to at least try and get this board to work before giving up and purchasing the C10. Another thing, mach3 doesn't seem to be working as well lol, wth. I installed it on to a new system, its running on vista. When I try and move the x,y,z axis with the arrow keys there is no movement in the coord's. It's works fine on my laptop but doesn't work on my desktop, what would cause that not to work?
    Aug 2010
    Gecko drive - input open-colect?
    http://www.cncitalia.net/forum/viewtopic.php?f=8&t=69471
    Mar 2007
    2083
    Re: 5 axis breakout board wiring PLease :'(
    it depends on which Gecko Drive your talking about
    the G540 opto-isolated inputs have the LED and 200 ohm resistor connected to a +12V DC supply
    so you need to connect the G540's input to either a open collector output or one that is compatable with 12V logic levels
    other Gecko drivers like the GM215 have the opto-isolator LED connected to ground and need to be connected to an output that can pull the input terminal up to +5V
    John
  1. CNC4PC.com C11 Breakout Board wiring.
    By thunderdork in forum CNC Machine Related Electronics
    Last Post: 10-29-2013, 06:53 PM
  2. Breakout board wiring help!
    By frostyshoal in forum DIY CNC Router Table Machines
    Last Post: 05-08-2013, 03:05 AM
  3. Single Axis TB6560 driver and breakout board wiring
    By badboy in forum Stepper Motors / Drives
    Last Post: 07-10-2012, 11:26 PM
  4. wiring Chinese Breakout board
    By silyavski in forum CNC Machine Related Electronics
    Last Post: 07-29-2011, 02:22 PM
