Hi Guys
I am such an idiot, I was testing the logic supply voltage on the L293 between pin 20 and ground (pin 16 on the schematic)and I had my multimeter plugged into amps and shorted something, duh.
The board still works, but there is a 10 second ish delay before it starts to track. Once tracking if I slew the motor to the right at full speed it takes about 10 seconds to start tracking again but if I choose a slower speed(you get 1 to 9) say 8 or below then it will track immediately.
Its like it is having to re-charge/re-buffer before it starts to track again.
Now if I slew the motor to the left then it will start tracking again almost immediately. so its a problem moving right.
I have found a schematic for the board but I am not 100% sure that it is correct as it is not a professional one, here is a link.The PIC's on the board are 16F876A and the L293 is 20 pin so the schematic is not perfect.
http://www.dd1us.de/Downloads/Schema...oard%200v2.pdf
I have checked the input to the L293 on pin 7 (which is the motor turn right pin) with a led and it flashes away ok when slewing the motor as soon as the button is released the motor stops and should start to track straight away but nothing happens. You can see the led is dimly lit for about 10 seconds then it jumps into life and the led starts to flash as it tracks. What could be causing the delay?
I hope you can understand this and have 5 mins to have a quick look at the schematic.
I think the L293 is ok as from my test it is not getting the signal to drive the motor from the 74HC240D for 10 seconds but what feeds the 240D. Could this be at fault? is it a lost cause trying to fix it? I don't know what to try next. I have found a new board on Celestrons web site for $89.00 but they do not sell outside the USA.
Thank you in advance for all your help and if you need any more info please ask.
Ceefna
