Originally Posted by
ihavenofish
in my experience, travel and clearance are clearly separated.
a guitar for example may be 3" thick max, plus 1" for a vaccum jig. so you need only a little ove 4" of clearance.
however, to drill a hole clean through the part, you need over 3" of motion, PLUS 3 more inchres for the tool clearance, plus the drill chuck, plus some safety. seems like only 3-4" travel needed at first, but consider your next tool to use might be a stubby 1/8" end mill with no chuck to register at jig level. you need alot more travel. i found 5" nowhere near enough. 8-10" would be ideal.
so i think you want the lowest amount of clearance you can get away with for the best rigidity, and the largest amount of z travel possible.
