I'm trying to define G23 as Store stroke limit function off
Can some one help please?
G22 X Y Z I J K
This sets the limits for the stroke check 2 called 'forbidden area'
XYZ sets the point on top at one corner
IJK sets the point at the bottom at the opposite corner
whether the forbidden area is inside the defined area or outside the defined area is set by a parameter.
G23 simply turns off the check.
If you have a Fanuc manual read the section on Stored Stroke Check
Never used G22.
Are IJK negative incremental values with respect to specified XYZ?
Thank you for the info.
I am trying to get an old machine build in 1992, to make a tool change it use to work with a G23 code.
We lost all the parameters that came with the machine, I was able to upload
a set of parameter similar to the original ones, the machine maker no longer has the original parameters, so they send me the ones I uploaded.
Now when it reads G23 I get "undefined G code".
It makes the tool change if I by pass the limit switch, I guess that's why it needs G23.
