586,463 active members*
3,483 visitors online*
Page 1 of 2 12
Results 1 to 20 of 41
    Feb 2007
    711
    CRP4848 in NC
    Hi, I plan to document some of my build and post a few pictures.
    I've been meaning to bring my camera to work to get some pics, hopefully this will help me remember to do it.
    I already have all my parts, I got the hardware only kit, and the diy nema 34 kit.
    my 3060 gantry came bent, so I am waiting for another to arrive so I will have to disassemble a little bit, and I'll take pics along the way.
    Don't get your hopes up yet, I only get a couple hours a week to work on it, so it may be a little bit before I have something to show.
    Mar 2011
    584
    bent 3060? wow!
    I hope to finish my wiring enough this week to get some movement out of my crp 4848. :cheers:
    Feb 2007
    711
    got some work done
    I got my new extrusion, put it on and took a few pics.
    you can see how the extrusion was bent in one of the pics, and the resulting gap on one of the bumpers. I was also able to get the Y axis mostly put together. Everything is going smoothly so far.
    I kept the bent extrusion, will try to cut it short and maybe use it as a bed for a small lathe.
    Feb 2007
    711
    I thought I'd give a little background
    I built my 1st cnc, a hotwire foam cutter in 2005 to assist with lost foam aluminum casting projects. cheap drivers and 1/4-20 leadscrews were the way to go back then. I had no idea 12 ipm was slow. Played with a sherline mini mill for a while, then started building routers. I wasted a lot of money and metal trying different designs, mostly using vxb linear shafts. When cncrouterparts came out with the rack and pinion system, I knew I had to have one. Luckily I came across a manufacturing company closing up, so I was able to buy ~150 feet of metric 4080 extra light extrusion, along with many fasteners and hardware, and a lot of other cool stuff for very cheap. I managed to get it all together with the metric stuff, only buying a 3030 gantry and 1530 z extrusion. I sold it recently, so time to build another!
    a couple pics of that setup, then its all crp4848 from here on.
    Attached Thumbnails Attached Thumbnails alansrouter1.jpg   alansrouter2.jpg   alansrouter3.jpg
    Mar 2011
    584
    I like how your gear rack mounts. Cleaner then the rack clamps. If you don't mind me asking what did that rack cost.
    Feb 2007
    711
    those racks are from fineline automation.
    I do like the rack clamps, but the racks I've gotten from mcmaster were hit or miss. they are $60 each plus $20 or so on bolts and tslot nuts.
    quite a bit more money than the other route, but I like them.
    Apr 2009
    266
    Quote Originally Posted by vtx1029 View Post
    +1
    so the FLA109-01 rack from Fineline automation works with the rack and pinion assembly from CNCRP?
    Feb 2007
    711
    I was doing a little checking/maintenance yesterday and realized I forgot 2 important steps when I put everything together.
    I never greased the Z axis thrust bearings. Oops! They were sounding nasty. Luckily with grease they are nice and quiet like they should be.
    Also I had never checked spindle runout before, and wow It was bad.
    I found my 0.125" calibration pin that came with some precise bits collets from an old router. 0.006" runout. And the pin only stuck out of the spindle half an inch.
    I never would have guessed. I still had my collet-care and found some cu-tips I was able to clean a bunch of gunk out of the taper.
    Now I'm getting between 0.0003 and 0.0025 (best I can tell with a 0.001 dial indicator).
    Im not sure if the remaining runout if from the spindle taper or from my collets. I got er20 collets from ebay seller halmia.
    They were $8 a piece and supposedly comforms to DIN 6499 standard. Not sure if there are any runout specs on that standard or if that just means its er20.
    I'd like to buy a couple collets with specified runout to check against. Also would like to get a longer gauge pin to know what the runout is an inch lower than I'm checking now.
    Feb 2007
    711
    Today I was trying to check how square the x and y axes are.
    What I ended up with was a 12x24 carpenters square clamped to the table, and probing the sides to see how far out it was.
    With clamps and stuff in the way, i probed 10 inches apart on the 2 sides of the square. I came up with a 90.008469 degree angle.
    If my machine travel is a parallelogram of 50 inches, then it will be off by 0.00147" at the limits of travel. Sounds right?
    (20in diameter * pi) / 360 = 0.1745 inches per degree
    0.1745" * 0.008469 degreees = 0.00147"
    Now this is assuming the cheapo square I am using is exactly 90 degrees, and my probe runout is exactly 0.
    Maybe I will get a quality one and check again some day.
    If thats right, then I wont bother with another Y home switch to square the gantry.
    Right now I am pulling it against the endstops, then turning on stepper power.
    Now if only I could get my bits to spin with less than 0.001 runout, I'll be happy.
    Sep 2011
    1183
    Alan,Why don't you cut some squares a couple different sizes and then take your measurements from the squares I would think you could tell if your off and which axis.
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Feb 2007
    711
    Quote Originally Posted by LouF View Post
    Lou
    I think that will work if I use an external measuring device. A tape measure and 6" calipers is all I have.
    I don't trust my tape measurements for being very accurate. I did measure a 4" wood square I cut out. 4.004" x 3.997"
    with corner to corner measuring 5.644" x 5.641". This gives me a 90.0305 degree angle.
    Now that I look back at my math, I think i forgot something. The machine will be off by 0.00147"X per 10"Y so at 50" my X will be off by 0.0147".
    That sounds more reasonable.
    Feb 2007
    711
    Re: CRP4848 in NC
    I am working on a cnc lathe that I am cutting out with my crp4848, and wanted to share some aluminum cutting success.
    I am cutting out 30mm aluminum plate. In the past I had been using onsrud 65-025 single flute bit, but was having problems with the tip chipping and at $45 a pop, I was looking for cheaper options.
    I ended up using this ebay bit, 1/4 diameter 1 1/4 flute length 2 flutes. 1 4" Carbide Router Bit 2 Flute Spiral Upcut | eBay
    My magic settings were 15000rpm 30ipm @ 0.070 DOC. comes out to exactly 0.001 IPT.
    It cut beautifully, though I did have to air blast the chips out after every pass. It took 17 passes. A little slow, but I will not be cutting metal that thick very often.
    One thing that was suprising, and I'm sure it was a fluke, all the dimensions of my parts the I can measure with a 4" micrometer came out to within 0.0001
    I'm not sure about the larger parts, but with a 12" digital caliper they are all within 0.001"
    I'm pretty impressed.
    Here is a link to the lathe build.
    http://www.cnczone.com/forums/vertic...cnc-lathe.html
    Feb 2007
    711
    Re: CRP4848 in NC
    I finally remembered to take a picture of something I made, I haven't made much in the past year, hopefully one day I will be unemployed, and that will change!
    It is a standing desk converter, just an extension to make it comfortable when standing at a desk.
    Now I just need to remember to use a better camera when taking pics.
    Attachment 250476
    Attachment 250478
    Attachment 250480
    Attachment 250482
    Sep 2011
    1183
    Re: CRP4848 in NC
    Alan, nice job I like it what kind of lumber did you use?
    Feb 2007
    711
    Re: CRP4848 in NC
    Thanks, It is MDF.
    I had planned on plywood, but didnt have any and didn't feel like going to the store.
    I was a little concerned because MDF usually has a poor looking edge after cutting out, it looked ok though.
    I wanted it to leak really nice, so I used a roundover bit with the bearing on it, lowered the router to the correct depth, and finished all the edges by hand, with the router stationary.
    I worked out really well, and I will do this in the future.
    I don't know why I hadn't tried this before, for some reason I though i needed a manual router table, but this works great.
    Sep 2011
    1183
    Re: CRP4848 in NC
    The MDF looks good.
    Feb 2007
    711
    Re: CRP4848 in NC
    Finally got around to cutting some steel on this thing. This is a 12-1 tooth trigger wheel for a motorcycle fuel injection system.
    Material is 1/8" A36 Hot rolled steel sheet.
    Cutting bit is a 1/8" 2 flute TiAlN coated carbide
    Cut settings for a very conservative 0.0003" per tooth chipload, but the end mill didn't seem to mind, and the part had a good finish.
    12000 rpms
    0.008" Depth of cut
    8 ipm
    Probably lots of room for optimization, but I don't think I will be cutting steel very often.
    Jan 2015
    194
    Re: CRP4848 in NC
    Nice! Steel? What machine(machine,spindle,base) do you have?
    Feb 2007
    711
    Re: CRP4848 in NC
    Thanks, It's the machine in this build thread. An original version of the cncrouterparts 4848 machine, with a chinese 2.2kw spindle
    Jan 2015
    194
    Re: CRP4848 in NC
    Wow. Nice. Thanks for sharing. Was that a dry cut or did you spray any lubricant?
Page 1 of 2 12
  1. CRP4848 - My first machine
    By Analias in forum Open Source CNC Machine Designs
    Last Post: 11-17-2014, 03:38 PM
  2. Also building a CRP4848
    By Tool Designer in forum Open Source CNC Machine Designs
    Last Post: 10-22-2014, 11:33 PM
  3. my crp4848
    By kjl-pdx in forum Avid CNC
    Last Post: 01-21-2014, 09:13 PM
  4. And yet another CRP4848 4x4 R&P CNC Router
    By rhadiem in forum Open Source CNC Machine Designs
    Last Post: 09-08-2012, 08:30 AM
  5. Questions about the CRP4848
    By jemmyell in forum Open Source CNC Machine Designs
    Last Post: 08-14-2012, 03:06 PM
