587,008 active members*
3,144 visitors online*
    Oct 2011
    Axis Drive Fault
    Ok so I bought a bridgeport vmc 760/22 and every time I try to run a program on it (going through all the correct steps in the manual) the spindle starts up, but then shuts off immediately and the machine turns off the drives and gives me the old axis drive fault saying that the drives are not turned on. This is when I manually create a program file on the machine typing in by hand the sample g-code from one of the manuals. Also after I load my program and try to view it in preview mode to see if the code is any good, my screens gets all blurry and only half of the user interface that is supposed to be on the screen actually shows up when in the preview mode.
    Also I have been looking through all the manuals and I can not figure out how to jog the spindle, so if anyone knows how to do that I would like to know.
    If anyone has ever run into this problem and knows what is going on, I would appreciate any help.
    Nov 2004
    3028
    I assume the machine homes?
    Have you set a tool offset?Have you gone to STM and entered a tool number and M06 to pick up that tool and offset? Then to STM again and entered a spindle speed and a M06?
    Then to the RUN screen, and MDI and done a feed rate move? Possibly followed by a rapid move?
    All this to step by step determine what works and what is failing you.
    George
    Apr 2016
    39
    Re: Axis Drive Fault
    turn the jog pot to + and push escape at the same time,now the machine are in home mode
  1. SPINDLE AXIS DRIVE FAULT
    By homezz in forum Haas Lathes
    Last Post: 10-04-2009, 04:25 PM
  2. 760-22 axis drive fault
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2009, 03:30 AM
  3. SL-20 A-axis drive fault
    By metaltec in forum Haas Lathes
    Last Post: 12-28-2007, 03:05 AM
  4. Z Axis Drive Fault
    By jeremy_d in forum Servo Motors / Drives
    Last Post: 08-16-2006, 04:04 AM
  5. Axis Drive Fault
    By Bluey in forum DNC Problems and Solutions
    Last Post: 11-04-2004, 01:54 AM
