Hi All,
I'm looking to be educated some on using the Newfangled Circle Cutting Wizard. When I attempt to use it, I keep getting a small movement out side the circle which creates a small arc in my work piece. I'm trying to cut an inside circle, so that creates a defect in the part.
I am enclosing the code generated by the wizard and a screen shot showing the little "dogleg" that it makes.
Any help or suggestions would be greatly appreciated.
Terry
