586,832 active members*
3,149 visitors online*
Thread: Programming
    Feb 2012
    Programming
    Hello I am new to this web site and thought I could use some help. Below is my program. When it gets to the reppetitive cycle it throws an alarm 064 shape program not monotonously. I have run the program without the G71 and it goes through fine. Please help.
    N10(PROFILE TOOL)
    G50S1500
    G0T1010M8
    G96S500M3
    G0G42X1.400Z.1
    /G71P100Q101U.02W.002S200D0250F.004R1
    N100G0X.825
    G01Z.02F.0015
    G03X.984Z-.2R.4125F.004
    G03X.825Z-.4R.4125F.004
    G01X1.225Z-2.02F.004
    G03X1.00Z-2.420R.550F.004
    G01X1.125F.004
    Z-3.1
    N101G0G40X1.4Z.1
    X5.Z10.
    T1000
    M1
    2932
    Quote Originally Posted by mschmitz88 View Post
    N10(PROFILE TOOL)
    G50S1500
    G0T1010M8
    G96S500M3
    G0G42X1.400Z.1
    N100G0X.825
    G01Z.02F.0015
    G03X.984Z-.2R.4125F.004 <---- increasing diameter
    G03X.825Z-.4R.4125F.004 <---- decreasing diameter (not monotonous)
    G01X1.225Z-2.02F.004 <---- increasing diameter
    G03X1.00Z-2.420R.550F.004 <---- decreasing diameter
    G01X1.125F.004
    Z-3.1
    N101G0G40X1.4Z.1
    X5.Z10.
    T1000
    M1
    You'll need to use a Type II cycle (if your machine is so equipped). Try adding a W0 to N100. Also, you don't need to repeat F.004 in each block.
    Feb 2012
    Will I beable to do this on a yasnac controll also or will it need something different
    Aug 2011
    2517
  1. Are you using WCS for programming?
    By Steve Arteman in forum Mastercam
    Last Post: 05-10-2012, 10:56 PM
  2. 2d to 3d programming
    By DALACHEAX1 in forum GibbsCAM
    Last Post: 06-13-2011, 11:31 PM
  3. Programming M02 / M30
    By TMILLS in forum Fadal
    Last Post: 11-30-2009, 09:08 PM
  4. cnc programming
    By ADELWEIS in forum Employment Opportunity
    Last Post: 06-29-2009, 07:06 PM
  5. CNC PROGRAMMING
    By PICMAN in forum G-Code Programing
    Last Post: 08-20-2008, 11:07 PM
