Hello CNC aficionados
I'm working on the completion of a 24 x 48" CNC router, based on the Solsylva plans. Early on, I have decided to use 2 steppers for the X-axis (the 48" direction) instead of 1 motor with a belt to drive 2 shafts. My feeling was that with a belt the torque was split in 2, so this axis would be weak....
I am using a Gecko G540 for controller, with a 24V power supply. I have 425ozin steppers on X and Y, and a 250ozin for the Z. All have a 10mAh impedance. I have found that this 10mAh impedance is not optimal for the G540 (2mAh would be better), but I am stuck with them...
Unfortunately, very often one of the X steppers loses steps when machine is routing and the whole thing jams. It forces and twist the rails and gantry, so it's very bad on the whole machine...
To fix that, I'm thinking of 1) upgrading to a 48V power supply, and 2)switch to a single X-direction stepper with the belt drive.
Do you think that will help my problem ??
