Has anyone here tried and inline tool oiler. I have been looking at different setups and this looks promising. I will probably get one of the SMC oilers as you can regulate the amount easily and see the amount of drops being fed into the air line.
I have always used flood coolant in the past but looking at better options and getting rid of coolant altogether. We already have airblowers setup on the machines and I just need a way of introducing a small amount of oil into the system.
I have heard that a mister system can cause problems with oil deposits everywhere but a quality tool oiler that you can regulate down to 1-2 drops / minute should not cause this issue as the oil will be burned of in the chips before it becomes a problem
Anyone have any thoughts.
When you come to a fork in the road take it
