Well hello...It finally nearly got me...nearly.
Today after 4months I discovered some stuff. My name is Brian by the way, Ive been a lurker on here for years so lets nobody panic now that Im out of the darkness!
Today, I loaded on Mach3.
A little bit of history. 4months ago I bought a Hurco Km3 that was faulty on the z.
I didnt even bother try fix it.
I ripped it all out and fitted a pmdx 126, 3 geckos(320x) the pc, and the twin P.port cards. All the parts I got of Steve, and boys, what_a great guy he is.
I got encoders off digikey, the amt102s.
Ill have a lot of questions here, so hopefully people will look, but, I have a major one first.
This morning, my horror was realised when I discovered my y motor is/was burnt to a crisp inside.
I almost went insane trying to tune it with the 126 onboard test function before that. It would not tune nice, and I had checked everything.
So..I carried on, hoping that Mach3 would drive it better.
It did not.
I had the machine all wired nice and good to go, so I had to undo a bit of that and bit the bullet and swapped the servo off the z, down onto the y.
What a difference that made. It was perfect.
I opened up the dud servo and Its windings are all shot. And for a long time too, I just noticed now.
So, the question is, where do I go from here. I think I should get a nema, and slap that on the z. I would then need a driver for it, since my own are 320xs.
Should I do this?
Will a stepper run off my power rail to 320xs and power a 203v?
Is it going to be a nightmare calibrate both the x/y servos, and a stepper on the z(quill)?
Servos seem to be insane money, and rare.
Im a mech designer and have all the other stuff needed to graft on a nema something to where the servo came off.
Is this the way to go folks?
I know the deal with steppers, lost steps etc, what do you think?
What size would I need for z, and is it a good Idea to mix and match steppers and servos in mach3, and both on the job.
Many thanks, and I intend having loads more questions along the way, but this Is my first on I couldn't find an answer for.
Other that that all the rest runs sweet as.
Is it worth getting a servo rewound? Its Like it went on fire inside...
Brian,
