OK, now having gotten back into it some more, after not having used Surfcam since V3, I am having a few problems getting a couple of things to work as they should. Some things have definitely changed since my last experiences, but there are other things I've just forgotten how to do...
1) Little tweak:
In the OM, the post *category* always defaults to 5 axis, I want it to default to 3 axis. Within the 3 axis category, I have the post I want as default - that I remember how to do in Surfcam.pst, but I don't see any setting in .pst for telling Surfcam that I want the 3 axis posts displayed as a default, nor in options, nor in any of the .ini's (maybe I missed something).
2) Bigger problem:
Verify... has changed a lot since I last used V3... and while I used to think it was actually pretty good back then, I'm now having a hard time with it. I have tried the different modes, currently using the "true solids" setting.
First, it just seems the "lighting" quality (for lack of a better description) is much too flat - it's hard to see what's actually being cut because the horizontal and vertical surfaces have the same uniform gray. I seem to recall that it had more contrast in the past.
Having two monitors, I don't mind that it is now in a separate window (except for the horrible unreadable toolbar icons), it does seem to take a long time to initiate... But, it seems to be playing havoc with my system. The simulations run OK, but after that, while the Verify window is open my whole system gets sluggish and jerky. I have to close out of verify and sometimes even Surfcam to get it to come back to normal. This is neither a CPU nor a memory issue - I have an i7 and 12 gigs of RAM and neither is being taxed at all with this stuff. On top of that, when the problem occurs, there's nothing that looks like it is actually running and taking up resources that could cause such a slowdown.
I therefore think it likely that it's a display/drivers issue. I have a GTX 280 graphics card, top of the line for 3 years ago and still pretty good, it runs every other 3D program I have fine - but it's not an overpriced Quadro.
So I just thought I'd ask - anyone else experience this sort of problem with Verify?
TIA, --ch
