586,616 active members*
2,421 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > partner 1 spindle drive problems
    Aug 2007
    64
    I'm having issues with my saftronics drive. It was working fine one day then i turned it on the next morning and the drive won't power on. No display, the machine comes out of e-stop and works fine aside from the spindle not coming on. The drive did occasionally come on for a minute and run the spindle but would go out again after about 30 sec. I checked the large relay inside and cleaned the contacts but it still didn't help. I suspect the transistor pack inside but i'm not sure if i can just test like rectifier or? Has anyone had experience with this issue or know of a replacment drive? I did read a thread about a v100 working but not with a toolchanger so i'm not sure what to do here but gotta get this going again ASAP. HELP
    (the last picture is one i found on the net of the transistor pack)
    Thanks!
    Attached Thumbnails Attached Thumbnails HPIM1887.jpg   HPIM1888.jpg   $(KGrHqJ,!jIE3SBQI7+zBN1Vclu44g~~_3.jpg
    Jul 2004
    97
    PC# Drive
    Aug 2007
    64
    That's where mine is right now, i wish i had found them sooner. Hopefully i'll be back and running shortly. They seem like really good people to work with.
  1. Spindle drive problems
    By functionbikes in forum Tormach Personal CNC Mill
    Last Post: 02-12-2009, 08:45 PM
  2. Partner IV w/Centurion V Problems
    By KurtsKustom in forum Milltronics
    Last Post: 05-10-2008, 01:53 AM
  3. PARTNER 7 DRIVE PROBLEMS
    By scorchtool in forum Milltronics
    Last Post: 01-22-2008, 01:52 AM
  4. Yaskawa AC Spindle Drive problems...blown?
    By nlh in forum Servo Motors / Drives
    Last Post: 08-04-2006, 01:19 PM
  5. Bridgport 300 CNC spindle drive problems
    By tenmetalman in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2006, 05:11 AM
