I have a 304 ss job. Its just about 7.1" long. The first 2.6" of OD is .472 +.0000 -.0004. Then it tappers down 1 degree for the remaining 4.1" with a full radius at the end of the taper. Also finish needs to be .032 or better. Any suggestions on turning this and keeping in the roundness, finish, and OD tolerance? Im using normal horizontal cnc lathe. Thanks in advance!!!
