586,471 active members*
3,698 visitors online*
    Dec 2010
    newb questions
    ok, i know this was probably asked a million times, but here it is again. can i cut 2,5D or 3D in kcam? i am close to finishing my little desktop machine, and the first things i will be making are improved bearing mounts, stepper mounts... obviously, this has to be done out of thicker material (let's say up to 40mm). can i cut it with kcam? i got a hang of the most of the kcam setup, but when i import a block with a central hole in dxf, all i get are lines, as if it's engraving in air, so to speak.
    any tips or tricks?
    Dec 2010
    to answer my own question, and maybe help others:
    of course it can. it's only a matter of importing files, or pre-written gcode. this is how i do it:
    first step: draw the object in sketchup. to export stl, you need the stl plugin you can get from here: su2stl (SU Plugin) - Ruby Library Depot. there is an explanation for installation. draw the object, export it (selected part or the whole thing) as .stl.
    step two: i am using meshcam, as i find it very simple and straight forward. you need to to some tuning before you can generate toolpath, but it's not a big problem. for exporting gcode, i use basic gcode mm/arcs.nc
    step three:import the gcode file into kcam. again, you will need to do some tuning, depending on your machine. then, cut.
    i think this would actually be 3D cutting, and it works for me. hope this helps
  1. NEWB build. I have some questions
    By mr_thehun in forum DIY CNC Router Table Machines
    Last Post: 04-07-2011, 05:03 AM
  2. Newb intro and a few questions
    By Mini Beast in forum Taig Mills / Lathes
    Last Post: 05-20-2009, 05:07 PM
  3. Bridgeport - newb questions
    By bjinatj in forum Bridgeport / Hardinge Mills
    Last Post: 01-13-2009, 06:59 PM
  4. Newb with some questions
    By junkxp in forum Rhino 3D
    Last Post: 08-23-2007, 03:21 AM
  5. Newb here, just a few starting off questions..
    By SlimJimmy in forum Waterjet General Topics
    Last Post: 04-27-2006, 05:56 PM
