586,359 active members*
3,435 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Harbor Freight router speed controller fix
    Dec 2006
    22
    I have a microcarve A4 table top CNC router. I have installed a Bosch Colt trim router as the spindle. The slowest speed that it will run at is about 15000rpm. I want it to run more slowly so I got a Harbor Freight router speed controller to control it. I disabled the soft start in the Colt and plugged it into the HF controller. Using my HF laser tachometer I measured the speed of the Colt. The slowest speed I could get with the speed controller was a little over 18000rpm! Not the direction I was hoping to go. Does anyone know how to modify the speed controller to get the speed of the router down farther? Or does anyone have a different solution for this problem without spending hundreds of dollars?
    Mark
    Oct 2008
    2100
    Get the fixed speed Colt instead.
    Bob La Londe
    http://www.YumaBassMan.com
    Bypass the variable speed electronics in the Colt, and you should have a fixed speed Colt.
    Dec 2006
    22
    The fixed speed Colt goes about 30000 rpm, so it doesn't solve my problem of lowering the speed.
    Super PID
    I know you said you didn't want to spend hundreds of dollars but the Super PID is a great value at around $155.00 if it will meet your needs.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Harbor Freight Plasma Cutter Retrofit for CNC Router
    By jurban in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-02-2014, 12:20 AM
  2. Super-PID speed controller installation to Fixed speed Router
    By Khalid in forum DIY CNC Router Table Machines
    Last Post: 11-13-2010, 11:29 AM
  3. Replies: 20
    Last Post: 05-27-2009, 04:29 AM
  4. Harbor Freight KX3
    By tracebender in forum Mini Lathe
    Last Post: 09-28-2008, 09:17 PM
  5. harbor freight
    By rs1300 in forum Benchtop Machines
    Last Post: 02-05-2004, 01:49 AM
