586,494 active members*
3,034 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > MFG CNC Machine Z-Axis Zero Tool Setter Pro -MADE IN THE USA-
Results 1 to 1 of 1
    Jan 2012
    NEW Tool Setter Pro by KLW Manufacturing and Design.
    • Easy to read indicator face.
    • Dramatically decrease set up time and eliminate tool path mismatch
    • Large contact face allows all flutes of the tool to make contact for the most accurate measurement.
    • Allows you to standardize the way tool offsets are measured in your shop.
    • Spring loaded setting face to safeguard against damage from overrun.
    • Anodized Aircraft grade aluminum body to resist wear and provide years of service.
    • Ensures every job is setup the same way and runs without issues.
    • Offset height 6.000 in
    • Stainless Steel Base and Button
    Sale Price: 149.99
    The Tool Setter Pro is proudly designed and manufactured in the USA by KLW MFG & Design - Arlington, WA
    For more information about the Tool Setter Pro or about our other products/services please contact us at [email protected]
    Attached Thumbnails Attached Thumbnails IMAG0097.jpg   IMAG0098.jpg   IMAG0099.jpg
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. tool setter
    By korte1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-20-2012, 05:21 PM
  3. Renishaw TS27R tool setter on HAAS machine.
    By JasonR in forum Haas Mills
    Last Post: 09-23-2009, 07:36 AM
  4. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
