586,263 active members*
4,230 visitors online*
    Jan 2012
    Unhappy Mori Seiki SL-250 Help needed!!
    I have a CNC Lathe Mori Seiki SL-250 with MSC-500 control (i have been told it is a Fanuc control not seiko), after losing and restore the parameters (due to a battery failure), the movements are ok on X & Z axes but the tool turret is misaligned, i mean when it moves towards the material in X axis, i can see the tool is below the center or rotation axis, it is like the clamping angle of the turret have moved.
    By the way the lathe has not crashed.
    Does anybody knows how to rotate the turret with the handle control to realign?
    Any ideas?
    Sep 2008
    100
    pues yo haria dos opciones.... dar de alta el eje de la torreta para poderlo manipular y otra desacoplando el eje... yo lo he hecho con hass, el eje no choco pero de todos modos perdio referencia por lo leido
  1. Mori Seiki ZL-15 info needed
    By wmpy in forum Mori Seiki lathes
    Last Post: 10-16-2011, 02:21 AM
  2. Help!! Mori-Seiki SL-25 Index Motor Needed
    By promexprecision in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2006, 03:38 AM
