586,396 active members*
2,911 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Help with material purchasing. Should I base my dimensions on the material available?
    Jan 2012
    113
    I need to make a product that is 30cm x 15cm x 1cm of Aluminum. I was wondering if it is best to try to source blocks of aluminum that are these dimensions or to get something a bit bigger and dimension it myself with a milling machine. It seems to be extra work to machine the dimensions myself. Getting my CNC machine in a couple weeks.
    - If I do use the ready dimensioned material, I am assuming that setting the zero access would have to be a lot more accurate than setting it when cutting out my own dimensions correct?
    - Would the finish usually be the same?
    Just wondering what most of you would do if you had this option.
    Mar 2006
    2712
    Depends on the required workpiece dimensional tolerances and finish requirements as well as the supplied material dimensional and finish tolerances. Check with the material supplier if he can meet your requirements.
    Dick Z
    DZASTR
    Jan 2012
    113
    thanks, so if I use precut dimensions I assume that the home zero axis has to be completely accurate. I will try both methods.
    Mar 2006
    2712
    Ex.; If your supplier can deliver 15CM wide X 1CM thick stock with the finish you require, all you would have to do is saw it into 30CM (plus a few MM for machining stock). Then locate the stock in a vise (as an example) and mill the ends to an accurate 30CM finished length.
    If any more features are to be machined, they could possibly be machined in the same set-up.
    Dick Z
    DZASTR
    Jan 2004
    3154
    I typically find that 6061 aluminum barstock is up to .01" oversize in most cases.
    Sheet stock is often different and I don't know what grade you are looking at.
    Also - good luck finding metric stock in Canada (and if you do it will be way overpriced)
    www.integratedmechanical.ca
  1. Material Manager/Purchasing Manager - IL
    By MachiningJobs in forum Employment Opportunity
    Last Post: 05-23-2011, 04:04 PM
  2. Overall Wood Base Dimensions
    By kemper45 in forum Momus Design CNC plans
    Last Post: 05-06-2011, 08:48 PM
  3. what material??
    By pauluk in forum Metallurgy
    Last Post: 05-19-2010, 11:35 PM
  4. Sieg X3 small mill base dimensions
    By JDCNCSolutions in forum Benchtop Machines
    Last Post: 01-14-2010, 06:47 PM
  5. Where do you buy material?
    By justgary in forum Want To Buy...Need help!
    Last Post: 04-21-2009, 04:17 PM
