586,377 active members*
2,376 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo motors rated at 85volts power supply at 100volts?
    Mar 2005
    271
    Question Servo motors rated at 85volts power supply at 100volts?
    My servo motors are rated at 85vdc 7amps,and are the motors that came with on the mill when I bought it,after putting power to the machine I took a reading at the motor input and it read 100vdc. Should I be making sure that it only puts out 85vdc max or should it be less,I will be using viper 200 drives and mach3.
    Any help would be great.
    Thanks Mike
    24223
    With PWM drives you can control the voltage mean level in order that the motor does not exceed its maximum rpm.
    100v on a 85v motor will do no harm, per-se, only if it was continuous causing overspeeding.
    Al.
  1. Power supply for my stepper motors
    By tmcp in forum Stepper Motors / Drives
    Last Post: 01-21-2009, 05:07 AM
  2. Is it mach 3, power supply or motors?
    By tauscnc in forum Mach Mill
    Last Post: 12-06-2008, 03:17 PM
  3. Question about power supply for the motors
    By SteveC68 in forum CNC Wire Foam Cutter Machines
    Last Post: 03-29-2008, 02:45 AM
  4. Help with Power supply or motors ?
    By rodzilla in forum Stepper Motors / Drives
    Last Post: 11-29-2007, 04:58 PM
  5. Power supply for 3 xylotex motors
    By PEU in forum CNC Machine Related Electronics
    Last Post: 06-18-2005, 07:07 PM
